Can't get Houdini VDB to be dense enough inside C4D
Yambo
Well, i'm probably missing something.
I'm trying to transfer VDB data from Houdini into C4D via the Octane Volume object VDB slot.
VDB loaded fine, and i can see the volume appears in Octane live viewer, but it is much less dense then VDB that generated inside C4D, via the Volume object or TFD.
Also, i need to put the VDB in Hectometers in order for it to be in the same size generated initially from C4D
So what am i missing? i made 2 videos:
1. Demonstrate my problem transferring VDB data from Houdini
2. Demonstrate how it is working properly with Octane Volume Object.
Ahmet, any idea what am i missing? maybe i'm not exporting the VDB right from Houdini? VDB file attached also.
Thanks.
stage.rar
(7.2 MiB) Downloaded 119 times
C4D VDB.mp4
(16.5 MiB) Downloaded 1592 times
Houdini VDB.mp4
(20.65 MiB) Downloaded 1593 times
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
glimpse
Shouldn't You play a bit with kernel settigns for volume objects as well? Try to tweak some options thre (sorry do not remember, pelase consult feature thread) but I noticed that some of those helped during tests I've done!
Hi Yam,
here is my attempt with scattering only and a Volume step length of 0.01 in the kernel settings:
stage_b.c4d.zip
(48.01 KiB) Downloaded 112 times
ciao beppe
Yambo
Thanks folks!
This is what i was missing
https://yambo.me
