Can't install plugin on new machine
Czapara
Hey there,
I'm new to Octane, and am trying to install it on a new machine. I am using the latest stable build of Octane (2.24?) and the latest production build of Lightwave (build2847). I have also updated the Microsoft runtimes as suggested in the manual, but Lightwave will still not recognize the plugin. I have double checked, and everything is 64-bit. Which rookie mistake am I committing?
thx
juanjgon
The last stable 2.2 plugin is the 2.25.0.0, but anyway the 2.24 should work fine.
If you have the Octane.dll and Octane.dat files in your LightWave/bin folder, and the Visual C++ 2012 redistributable package installed, can you please add also to your LightWave/bin the attached .dll file? ... The problem can be that the Octane API needs the Visual C++ 2010 redistributable in the system, or the attached .dll, to work.
If this doesn't work, please let me know.
vcomp100.rar
(25.25 KiB) Downloaded 154 times
Czapara
That did the trick, thanks!
Return to “Lightwave 3D”
