OctaneRender 3 for AutoCAD [OBSOLETE]
Autodesk AutoCAD (Integrated Plugin developed by OTOY, maintained by Paul Kinnane)
guillerodriguezv
Correction is Octane Stand Alone Alpha 2.
Laptop- Win 10 64- 32 Gig GTX 880m 8 Gig - Desktop Win 10 64- 16 Gig GTX 980 ti 8 Gig
the only change that I see is that you can not use the plugin offline. Please check this because if the internet fails you can not use it. The same is for the Octane stand alone v3 beta.
Yes - I think this is deliberate, and only during the alpha and beta period. You should be able to use the plugin offline in the post-beta version.
3.0.6.13
- Compiled with Octane 3.0 alpha 6. Note the minimum Nvidia driver required is 353
guillerodriguezv
Hi Paul,
I just realize that Autocad 2017 just realeased a few days ago, I have not tried yet, just to remind you if you tried it ,please check if supports AEC objects into the plugin... :D maybe I hope this time around.
Guillermo
In my experience, unless many people request a feature from Autodesk, it will not be implemented.
I will do a new installer for AutoCAD 2017 shortly after the Easter break.
guillerodriguezv
Hi Paul
Any good news about Autocad 2017 Pluggin with AEC objects support ???
Guillermo
I have downloaded and begun the plugin build process but not got everything working yet. I cannot see anything able AEC object support in the API changes, but will know more in the next day or so. http://hyperpics.blogs.com/beyond_the_u ... ation.html
I have been able to convert to plugin to work with AutoCAD 2017. And no, sorry, AutoCAD 2017 still does not support accessing the geometry for AEC objects. Is someone able to test the 2017 version pls?
https://render.otoy.com/customerdownloa ... _64bit.exe
guillerodriguezv
Hi Paul
Installed and testing on Autocad 2017 ... :)
guillerodriguezv
Hi Paul
I had been testing the plugin in Autocad 2017 and I had found some differences in triangulations comparing with Autocad 2014, both plugins lastest version (v 3.06).
regards
Guillermo
EXAMPLE-OCT.rar
dwg File
(2.14 MiB) Downloaded 584 times
Autocad 2017
Autocad 2017
Autocad 2014
Autocad 2014
Return to “Autodesk AutoCAD”
