OctaneRender 3 for AutoCAD [OBSOLETE]
- guillerodriguezv
Correction is Octane Stand Alone Alpha 2.
Laptop- Win 10 64- 32 Gig GTX 880m 8 Gig - Desktop Win 10 64- 16 Gig GTX 980 ti 8 Gig
Yes - I think this is deliberate, and only during the alpha and beta period. You should be able to use the plugin offline in the post-beta version.the only change that I see is that you can not use the plugin offline. Please check this because if the internet fails you can not use it. The same is for the Octane stand alone v3 beta.
3.0.6.13
- Compiled with Octane 3.0 alpha 6. Note the minimum Nvidia driver required is 353
3.0.6.13
- guillerodriguezv
Hi Paul,
I just realize that Autocad 2017 just realeased a few days ago, I have not tried yet, just to remind you if you tried it ,please check if supports AEC objects into the plugin...
maybe I hope this time around.
Guillermo
Guillermo
In my experience, unless many people request a feature from Autodesk, it will not be implemented.please check if supports AEC objects into the plugin...maybe I hope this time around.
I will do a new installer for AutoCAD 2017 shortly after the Easter break.
- guillerodriguezv
Hi Paul
Any good news about Autocad 2017 Pluggin with AEC objects support ???
Guillermo
Guillermo
I have downloaded and begun the plugin build process but not got everything working yet. I cannot see anything able AEC object support in the API changes, but will know more in the next day or so. http://hyperpics.blogs.com/beyond_the_u ... ation.html
I have been able to convert to plugin to work with AutoCAD 2017. And no, sorry, AutoCAD 2017 still does not support accessing the geometry for AEC objects. Is someone able to test the 2017 version pls?
https://render.otoy.com/customerdownloa ... _64bit.exe
- guillerodriguezv
Hi Paul
Installed and testing on Autocad 2017 ...
- guillerodriguezv
Hi Paul
I had been testing the plugin in Autocad 2017 and I had found some differences in triangulations comparing with Autocad 2014, both plugins lastest version (v 3.06).
regards
Guillermo
regards
Guillermo
- EXAMPLE-OCT.rar
- dwg File
- (2.14 MiB) Downloaded 522 times
