Cannot get X-Particles and C4DR17 to work together.
I have the latest versions of both plugins, but since the release of R17, I cannot do or see anything with Xparticles in Octane. Any piece of advice here? Even scenes that work just fine in R16 do not show anything in R17. Thanks, your help is appreciated!
Ryzen 5950x - 2X RTX 3090 - 128GB RAM
Windows 11
Windows 11
I remember this question from somewhere. Can i advice to check the topics which contains xparticles title in this forum?
Thanks, but I already did that. Nobody seems to have posted this problem. There are people who didn't have object tags and things like that. I do notice that I'm running version 2.32.2 in R16 and then in the latest version in R17 there is no place to check "enable particle engine" in the options in live viewer. Any other thoughts?
Windows 11
Windows 11
Give up 2.23, please go with latest 2.25-R3. It's under Cinema4d->Releases
viewtopic.php?f=85&t=52422
I removed this option and the usage replaced by object tag->particles. Please locate sample scene in next links..
viewtopic.php?f=30&t=52708
viewtopic.php?f=30&t=52557
viewtopic.php?f=30&t=52139&start=10
Thanks, got it working a second ago. I didn't realize I needed to check the appropriate boxes within the object tags. Hope this works as well as before. Thanks for the help!
Windows 11
Windows 11
- JonathanWinbush
- Contact:
I'm using R17 and have the trial version of x-partles 3.5 and was also testing this out I updated to octane 2.25 R3 but I can't get my particles to display either.
Funny thing is when I use the regular emitter that comes with cinema I can get the particles to display with the object tag but not with x-particles.
Is this because I have the trial version?
Winbush.tv
Win10x64 / i7 SkyLake / Nvidia Titan X + 980ti / 32gigs Ram
- JonathanWinbush
- Contact:
Can anyone post a simple scene I can try out maybe i'm missing a step somewhere but I've followed everything I've seen in these forums
Winbush.tv
- feinschmecker
You need to add the Octane Object tag to the emitter object itself - not the entire system. When it's on the emitter, you will see an extra particle particle tab.JonathanWinbush wrote:Can anyone post a simple scene I can try out maybe i'm missing a step somewhere but I've followed everything I've seen in these forums
/feinschmecker
- chrisfranklin6002
Same issue - guessing its the demo version...
XP api is not available on demo versions. So direct access is not possible for particle data.chrisfranklin6002 wrote:Same issue - guessing its the demo version...
