UV's - a better way??
createvfxinc
Seems like everytime I use Octane I'm dealing with UV issues via the Modo plugin. Is there a better workflow coming soon to the Modo plugin that will better deal with UV's? I'm almost at the point where the frustration is making me want to stop using Octane.
Win 8.1/ dual GTX 980 / i7 5960 4.2 Ghz
What UV issues are you having?
joshkitney
I've learn't, now, to be very diligent with meshes and UV's with Octane/Modo.
Normally I wouldn't care too much when working in Modo as it deals with them all good enough.
But with Octane I make sure all single meshes have single UV's (and good ones at that). No more messy UV lists for me.
i7 5960X Haswell-E 8-Core OC 4.2GHz // 2x GTX 980 Ti Superclocked+, 1 GTX 670 // 64GB's // Windows 10
TheImageFaculty
Yep, just discovering this myself. I have had strange results with modo UV nodes plugged into the projection slot of images.
From what I can see it's best to ignore using modo's projections and instead use the octane projection nodes and make sure they are pointed at the correct UV set. And as you say Josh this is totally dependent on having an ordered list.
The Image Faculty ApS
https://theimagefaculty.com
If someone sends me a scene showing this problem, I can take a closer look.
Return to “Foundry Modo”
