Anyone have a method for creating a good leaf material? One that has some translucency when backlit from sun?
I have all the texture images etc....just don't know what nodes to try for the translucency, back lit part. Thanks.
Good Leaf Material?
- 3dreamstudios
I'm probably doing something wrong...but I can't get absorption or scattering to work on single poly leafs....I guess it needs volume?
How can we create this illusion?
- FrankPooleFloating
Yo!
http://cgpress.org/archives/200-free-ph ... ssets.html
I bought the full pack for $6.. haven't checked them yet, but sure they're great.
I use a mix material for complex vegetation calculation.
One diffuse mixed with a glossy material.
The diffuse has transmission in it. I change the mix weight more to diffuse if I want them to be more light transparent.
The diffuse and glossy can have a mixed texture itself. With two sided material (polygon side).
Also you can mix the color variation with a falloff in it to get different color variations per tree.
I use the 3dsmax plugin but I guess the maps are the same.
PURE3D Visualisierungen
- BorisGoreta
- Contact:
U don't have to use medium nodes or scattering, just use diffuse material and plug leaf color image note into diffuse and transmission to also get the back lighting. There is a procedural node called polygon side if you want to have different textures on leaf sides but I don't use this. Also you can mix this with a glossy material to get some reflections on them.
- LightwaveGuru
- Contact:
look that video...i show your there what you have to do if you need leafs including light transmission support...(for PT-Kernel)
you need for that not a double sided polygon...
https://www.youtube.com/watch?v=0___SC5O2FE
snip lw guru
snip lw guru
http://www.neotek.laboratories.de or http://www.youtube.com/c/Lightwaveguru or http://www.facebook.com/safarifx 4x Titan X 12 GB watercooled / 6x 2080 ti air cooled / 2x 980 ti watercooled
- LightwaveGuru
- Contact:
p.s.3dreamstudios wrote:Anyone have a method for creating a good leaf material? One that has some translucency when backlit from sun?
here some examples as stills...(click it for bigger resolution)
snip lwguru
- ristoraven
