Feature requests
Moderator: BK
linvanchene
Elele wrote:Also there is an additional "my presets" list under the "used" and "emitters" lists.
It is pretty useless... [...]
The idea at some point was to add the ability to add folders so it would be possible to create some kind of groups in the "My presets" similar as there are groups in the liveDB.
Example: Redspec created materials for different characters and base figures which are supposed to be saved in "My presets". It is currently impossible to group them in a logical way with one folder of materials per product.
Win 10 Pro 64bit | Rendering: 2 x ASUS GeForce RTX 2080 Ti TURBO | Asus RTX NVLink Bridge 4-Slot | Intel Core i7 5820K | ASUS X99-E WS| 64 GB RAM
FAQ: OctaneRender for DAZ Studio - FAQ link collection
Hydra
I'd like folders in MyPresets. That would make using Redspec a lot easier.
Intel i7-4790K, Asus Z97-A, Corsair 32GB DDR3 1866MHz CL9, 2XAsus STRIX GTX980 DirectCU II OC 4GB, 4XSamsung 840 EVO Raid 10, Win 7 x64 Pro.
DrHemulen
Agree, that would be a really useful addition.
GTX 780, 6 gigs of VRAM - Win 7 Home Premium 64 bits
Whilst I like this suggestion - it's a convenience feature, so would be very low priority compared with HDR Light Studio and LAMH support, so I doubt it's something I could add in the near future.
linvanchene
Another case of could be useful but not that urgent.
- OctaneRender Preview viewports directly integrated into the DAZ Studio UI.
- having multiple OctaneRender preview viewports open at the same time
- separate "Kernelsettings" could be applied to the integrated preview viewports.
- the preview "Kernelsettings" could be adjusted in the "Draw Settings" tab of DAZ Studio.
OctaneRender main viewport with two (Iray) preview viewports active at the same time
"Draw Settings" for the preview viewports to adjust kernel quality for preview if needed
Example:
The main OctaneRender viewport is used to adjust camera, focus, selecting materials with shortcuts to the NGE as before.
The additional "preview viewports" would provide information how changing some settings would affect the scene from different camera angles.
garand3d
Paul, would you consider implementing the following in the future?:
1. It would be nice to have Octane keyframes appear on the DS timeline, and to add the option to 'auto-key' everytime we make a change.
2. An 'undo' function to the plug-in (or the NGE at least)?
Thanks.
Win 10 Pro 64bit | 2 x ASUS GTX TITAN BLACK, 6GB GDDR5 | Intel Core i7 3770K, 3.50 GHz | 32 GB RAM
MSI GT83VR SLI 7RF | Win 10 Home | 32 GB RAM
DAZ Studio Pro 4.10.0.123 | OR S.A. V3.01.1b | OCDS V3.8.2.39 | GeForce Driver 398.36
morphious2013
BATCH RENDER!!!!!! UGH.
Gateway i5 3.2ghz, 16g RAM, GTX 690 4GB VRAM, Windows 10 64bit, Poser Pro 11, DAZ Studio Pro 4.9, Daz Octane Plugin V2, Poser Octane Plugin V2
This would be a highly complex change - and I doubt it's something I could implement - sorry.
The NGE is implemented using a third party library, which does not support 'undo', so unfortunately I don't think this would be possible - sorry.
This would be complex to implement in DAZStudio, since the plugin would need to be loading scenes then rendering. A more viable solution would be to export your scene(s) to ORBX, and then use a batch render script in Octane Standalone to render and save the final images.
morphious2013
In Poser I can just do 50 scenes in one document by key framing each figure in each fram. Tried that in Daz and didn't work. Any ideas?
DrHemulen
face_off wrote:This would be complex to implement in DAZStudio, since the plugin would need to be loading scenes then rendering. A more viable solution would be to export your scene(s) to ORBX, and then use a batch render script in Octane Standalone to render and save the final images.
This works perfectly fine with standard scenes but goes a bit crazy when using geo-grafts.
Return to “DAZ Studio”
