Version 2.26.1 (28.11.2016) - Obsolete Stable
FAZ wrote:No, I know how opacity works. I tried re-installing the plugin but also deleting my c4d preferences this time, and the refractions are back and working fine.
Doesn't make any sense. There is no relationship for plugin preferences or i don't get what you mean.
FAZ wrote:As for the LiveDB, it is still not showing up in the drop down, but I can access it by hitting shift+c and searching "LiveDB". I just made a button out of it as a work around.
The LiveDB should be in the Pluigins drop down, then the C4doctane drop down menu. Correct? If that's where it belongs, it's simply not there anymore.
LV->materials->livedb
or
in commands:
open livedb
fuchsundvogel
is it normal that i lost samples when network clients are disconnected?
for example i have a rendering with networkclients and in the renderinfo i see spp/maxspp: 1200/2500. after i close the standalone renderclients the value is only 500/2500.
fuchsundvogel wrote:is it normal that i lost samples when network clients are disconnected?
I'm not sure but propably yes it's.
atome451
Thanks for this new version Aoktar. :)
There is the same problem with this version as i have posted in this thread for the previous version : viewtopic.php?f=30&t=52372
When i call the Octane Texture Manager from plugin menu, on my desktop or my laptop (Windows 10 64b with Cinema 4D R14 in both cases), the wheel appears and turn indefinitively and i have to kill Cinema 4D in the most cases or C4D crashes. Even if i have only one texture used in the project and only one path in preferences without special characters. The hard disk doesn't work more 10 or 15% (simple background processes, nothing for C4D) and the CPU do nothing special... I've tried to wait for 10 minutes before killing the process with no success.
If i have nothing in the project (only one cube and an Octane material applied without any texture), the Octane Texture Manager opens.
  • 1/ if i keep the Octane Texture Manager open
    2/ load a material and apply it to the cube
    3/ load an ImageTexture in Diffuse and a simple jpg from the path in preferences (without special characters)
    4/ click on the button "Update list"...
The wheel appears and turn indefinitively (more often) or C4D crashes...
If i keep the Octane Texture Manager closed before loading an ImageTexture, when i load it, the wheel appears and turn indefinitively. With or without the Live viewer running.
I hope these informations will help you.
_BugReport.zip
Here is the bugreport after a crash
(29.51 KiB) Downloaded 349 times
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
atome451 wrote:Thanks for this new version Aoktar. :)
Checking. It seems belongs to R14.
sodapop66
Hi Atome
you can try to change our french C4D language to english, for me some problems with octane have been solved with it
Thierry Tutin
Nice, France
atome451
sodapop66 wrote:Hi Atome
It's a good idea but it changes nothing in this case.
Anyway, i'll keep this trick in my toolbox of possible solutions when i'll have another problems with C4D. Thanks. ;)
atome451
Ok. Thanks Aoktar. No a big problem for me. It was just for your information. :)
sodapop66
Hi Aoktar
with C4DR16, i have recurring application freeze with drag and drop action from materials window to LiveDB windows (material out display message in the bottom)
Thierry Tutin
Nice, France
Yambo
sodapop66 wrote:Hi Aoktar
livedb also freeze for me a lot.
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
Return to “Releases”
