Heavy Scene Loading....19M Triangle Rendering Error.
CUDA Error 719...
But, No Textures, No Node, 30M Over Box Triangle Poly
There is no error.
Log file Upload....
help.
System Lightwave 2015.3, Titan X 32G Ram Windows7
Octane 3.0 alpha 4 19m Triangle Crash..Help
- octane.log
- (1.63 MiB) Downloaded 164 times
Alpha 4 should have the triangle limit removed, as far as you have enough free GPU RAM. Can you send to me your scene to test it here? ... you can use my email [email protected]
One question, do you have the out-of-memory feature enabled? This is the log where the scene crash. I can see that you have also a lot of textures loaded. Can you try to render your scene without textures, only with the geometry, to see what happens.
00:05:32 (0332.66) * OCTANE API MSG: CUDA error 719 on device 0: An exception occurred on the device while executing a kernel. The context cannot be used anymore and must be destroyed. All existing device memory allocations from this context are invalid and must be reconstructed.
00:05:32 (0332.66) * OCTANE API MSG: -> failed to deallocate device memory
00:05:32 (0332.66) * OCTANE API MSG: -> could not get memory info
00:05:32 (0332.66) * OCTANE API MSG: device 0: failed to upload data texture 4 of context 0
00:05:32 (0332.66) |
00:05:32 (0332.66) | ++++++++++++++++++++++
00:05:32 (0332.66) | +++ RENDER FAILURE +++ processing the failure callback
00:05:32 (0332.67) | <> Mem Used/Free/Total: 2651 / 6708 / 12288
00:05:32 (0332.67) | <> Triangles/DisplaceTris/Hairs/Objects/Voxels rendered: 19406677 / 0 / 0 / 230 / 0
00:05:32 (0332.67) | <> Textures RGB32/RGB64/GREY8/GREY16 used: 97 / 0 / 55 / 0
I'm currently testing a bet that the Titan X Rendering How many triangles.
If 4GB of memory to bring up the 20 million Titan X it should work to 60 million.
But, unfortunately, I have CUDA 719 Error occurred in 42 million.(No Texture Box.)
If you do not use quite the texture is 20 million can be used.
However, an error occurs before using certain thing all of Ttan X memory. Can that will test the Titan X?
I think.
12GB memory is not supported properly.
My System Out of Core 8GB Setting.
00:03:26 (0206.50) | <> Mem Used/Free/Total: 0 / 12059 / 12288
00:03:26 (0206.50) | <> Triangles/DisplaceTris/Hairs/Objects/Voxels rendered: 42240000 / 0 / 0 / 22 / 0
00:03:26 (0206.50) | <> Textures RGB32/RGB64/GREY8/GREY16 used: 0 / 0 / 0 / 0
00:03:26 (0206.50) | ... Init rendering ...
00:03:42 (0222.92) * OCTANE API MSG: CUDA error 719 on device 2: An exception occurred on the device while executing a kernel. The context cannot be used anymore and must be destroyed. All existing device memory allocations from this context are invalid and must be reconstructed.
00:03:42 (0222.92) * OCTANE API MSG: -> failed to launch kernel (ptBrdf1)
00:03:42 (0222.92) * OCTANE API MSG: device 2: direct light kernel failed
--------> 42M Triangle Cuda 719 Error
I think.
Sorry, I don't have here a Titan X to make this test win 12 GB of GPU RAM.
Can anyone with Titan X GPUs try to render scenes with 20, 30, 40 and 50 MTriangles to see what happens? ... anyway I will report this issues to the Octane developers.
1.024M * 37 Triangle Render Pass 37.888M
1.024M * 38 Triangle Render Error 38.912M Titan X *3
1.024M * 38 Triangle Render Pass & Error 38.912M Titan X *1
00:02:33 (0153.25) | <> Mem Used/Free/Total: 5405 / 6394 / 12288
00:02:33 (0153.25) | <> Triangles/DisplaceTris/Hairs/Objects/Voxels rendered: 38912000 / 0 / 0 / 38 / 0
00:02:33 (0153.25) | <> Textures RGB32/RGB64/GREY8/GREY16 used: 0 / 0 / 0 / 0
00:02:33 (0153.25) | ... Init rendering ...
00:02:50 (0170.26) * OCTANE API MSG: CUDA error 719 on device 2: An exception occurred on the device while executing a kernel. The context cannot be used anymore and must be destroyed. All existing device memory allocations from this context are invalid and must be reconstructed.
00:02:50 (0170.26) * OCTANE API MSG: -> kernel execution failed (report)
00:02:50 (0170.26) * OCTANE API MSG: -> failed to launch kernel (ptBrdf2)
00:02:50 (0170.26) * OCTANE API MSG: device 2: direct light kernel failed
How many times we've tested, whether there is a problem in more than 38 million Triangle, it is difficult to determine whether an error in the memory more than 5.5GB.
However, the heavy Scene contained in the texture of the Triangle 20 million and an error occurs.
After all it seems the problem is memory.
Or do not properly support the Titan X ...
Guys, if you have scene for downloading i can test on my TitanX.
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
Lewis
Skype - lewis3d
ICQ - 7128177
