Modo LiveDb empty materials
Hi - I have identified an issue with the current LiveDb download process - working on a solution at the moment...
I have refreshed the LiveDb downloads to hopefully fix your issue. Pls see the release notes for TEST release 3.0.4.95 for details.
- cristiangiro
Thank you so much Paul,
working for me either!!
Hi Fred, have you re-downloaded and installed the LiveDb as per https://docs.otoy.com/Modo/?page_id=909?
Hi, Fred,fmuram wrote:Hi Paul,
I am experiencing this same issue now that I have upgraded to the newest build.
Fred
I, too, experienced the same problem after upgrading and following the information here: https://docs.otoy.com/Modo/?page_id=909. But there were a couple of ways to fix it.
Solution 1: Reload the scene by pressing the reload button on the Octane toolbar. So, when you drag the Octane material from the root of the Shader Tree into whatever material group you created for your model and the Octane material doesn't load, hit Reload.
Solution 2: If that didn't work, try adding a UV map to your model. Make sure to delete the default "texture" UV map in Modo and create a new one. Finally, apply the Octane material.
Hope that helps.
Adam
