Version 2.24.2-R2 (22.01.2016)
fuchsundvogel
i wanted to achieve an uneven distribution. i thought for this is the shaderinput in distribution.
then i can control the distribution with the min and max slider. But this works only when i scatter only 1 single object. as soon as i scatter more than 1 objects this workflow dont work. because this sliders also influence which objects are used for scattering or not.
for example if i have 3 objects in scatterobject and the minslider is on 0.5, the first ibject is not used for scatter.
its more clear if you just use a gradient instead of noise
is this intended?
scene.zip
(218.59 KiB) Downloaded 238 times
rodross
aoktar wrote: This version and V3 is based on same codes. This version and TEST version are based on same SDK. So network rendering is same. Render failures is not plugin issue.
Anyway if we can't find that you'll see same problems on V3. Why don't you send me better info?
I gave you all the info I have. Working with xrefs, LV open, net rendering running. One computer was freezing really badly, the other was getting render failure (not talking about the slaves) . Identical computers, OS, drivers, everything the same. Then after swapping back over to 5.2, everything worked fine. Unfortunately, I cannot send you the files right now because #1 there are about 5-10 different xrefs attached to it, and #2 NDA. I'll see if I can get that relaxed so I can give you files to try so I can help you get any issues resolves so we're both happy :).
aggiechase37
I'm getting tons of crashes using hair on this. Are there known issues with hair rendering? It seems to do fine unless I make the length at 1%. At that point the render says it's going to take hours, and then the GPU driver crashes.
Chase
Win 10 - Intel 4770 - 2x Nvidia 1070 - 32 gigs RAM - C4D r16
http://www.luxemediaproductions.com
aggiechase37 wrote:I'm getting tons of crashes using hair on this. Are there known issues with hair rendering?
Do you think to share any bugreports? I can't see any crashes here.
To everyone, please share scenes/bugreports, full version informations, driver version, OS information your previous stable version.
I'm not really expecting that a lot of crashes.
DinoMuhic
I think I found a bug: It's not possible to drag and drop multiple materials into the node graph anymore. Or drag a second material into a graph where already a material is, so you can connect them together. This definately worked in the latest stable build.
Using R17.048 on Win10 Pro with a GTX780.
rodross
Maybe draw up a template and sticky it to the main C4D forum with how you want the info and people can copy+paste and never forget to put in all that info, e.g.,
C4D Version: 17.048
Octane Version (with issue): 2.24.2 R1
Octane Version (previously working): 2.24.2 TEST5.2
Driver Version: Nvidia 361.43
OS Version: Win 7
Description/Reproduction Steps:
No bug report produced but Octane no worky and I'm mad bro!
Open attached file, click button A, change setting B, scream at screen, then should crash
Scene and/or Bug report
aggiechase37
DinoMuhic wrote:I think I found a bug: It's not possible to drag and drop multiple materials into the node graph anymore. Or drag a second material into a graph where already a material is, so you can connect them together. This definately worked in the latest stable build.
So now all of a sudden it's acting good and I can't get it to crash. If it happens again I'll do bug report and scene file.
As a general question though, are there limitations about rendering hair that we should try to stay under? Hair count max? Length max/min? Anything like that?
Thanks.
Chase
This is from my all release threads. As you can read that's here as my requests from posters. This is very similar request as Maxon,etc.. does
Thanks.
Octane always have some limits on geometries, etc.. due VRAM and geometry limit. Sorry that's not meanful for me. Plugin doesn't act randomly. Maybe somethings are different due your usage, plugins, drivers, etc... If you create millions hair and make critisms about freeze, etc... that's not issue about plugin. Also plese always try to put a bugreport, scenes, etc... as i described in first page.
rodross
Is there a way to get useful raw data from a freeze similar to a bug report?
Return to “Releases”
