cuda error 700 on slave [OBSOLETE]
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
rappet
Hi Paul,
I got a cuda error 700 on slave
slave:
master:
Any idea?
greetz,
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
rappet
Same scene, another render target.
On one slave it has errors, on the other slave no problems.
Hi Jeroen - perhaps there is an issue with the card or driver on that particular slave? Suggest making sure all the drivers are the same, and install Octane Standalone via the installer EXE to ensure the nvidia timeouts are correct. If you export that scene from ArchiCAD to Standalone and network render from there - does the error still occur?
rappet
face_off wrote:Hi Jeroen - perhaps there is an issue with the card or driver on that particular slave? Suggest making sure all the drivers are the same, and install Octane Standalone via the installer EXE to ensure the nvidia timeouts are correct. If you export that scene from ArchiCAD to Standalone and network render from there - does the error still occur?
Hi Paul,
The driver update did not do the job. I will try and install the Standalones again to be sure that is correctly done.
greetz,
Edited: reinstalling the standalone did not fix it either.
Edtiedt2: The slave PC is very slow and gives blue screen too. Yhe C hadrdisk was getting full too.
I will clean up first to see if that will help.
Can there be any link with the 700 cuda error?
After free up space, clean windows, and other things I tried again, and still I got this error;
rappet
Hi Paul,
I also tried standalone 23.1 (instead of 24.2) and I get also the cuda 700 error on device 1 on slave when networkrendering.
Then I rendered on the machine with trouble on device one with the standalone to see if it only when using it as networkrendering.. and one gpu failes.
In log it says:
"CUda error on device 1: Errror code unknown
-> failed to unload module"
Might one GPU be broke, and shall I better post this issue in general forum?
greetz,
abstrax
rappet wrote:Hi Paul,
In log it says:
greetz,
Sounds like a hardware issue, but to be sure please send us the scene with which you can reproduce the issue and also the GPU model you are using.
rappet
In log it says:
greetz,
I am afraid so. The error occurs with all scenes (I tried the benchmark scene), so sending a specific scene has no use.
The model is 780Ti. But only one of the three is having the error.
I will try to locate which one, and swap the slots they are in to see what happens.
Do you have any suggestion for me to test and figure out what kinf of issue this can be?
Jeroen - try under-clocking the faulty card.
rappet
face_off wrote:Jeroen - try under-clocking the faulty card.
uptill now underclocking seems not to work... even got a bluescreen when underclocking.
and temps are not getting high
greetz,
This is the log I get:
Started logging on 11.01.16 12:27:17
OctaneRender 2.24.2 (2240001)
CUDA error 719 on device 1: An exception occurred on the device while executing a kernel. The context cannot be used anymore and must be destroyed. All existing device memory allocations from this context are invalid and must be reconstructed.
-> kernel execution failed (dl)
device 1: direct lighting failed
-> failed to clear linear 2D device memory
-> failed to allocated device memory
devic
edted: next time I got a cuda 715 error,
SO 700, 715, 719.. what does that say?
Sounds like a faulty card.
Return to “Graphisoft ArchiCAD”
