Version 3.00 - Alpha10.1 (30.04.2016)
xcaseyx
Thanks!!
I am anxiously waiting for xpartcles support and teasers.
With this alpha of se how much of the stuff you said would be possible in 3.0 is available. Will there be further mograph support coming too? Multi shader beat shader. Or even the cinema 4d proximal shader?
xcaseyx wrote:Thanks!!
It simply supports xparticles as allows of capability of Octane. But for assigning per particle colors are not possible on render instances.
Multi shader and mograph colors should work on non-render instance instances. Both is same reason. We don't have a shader type to use on render instances.
xcaseyx
ohh I see, is support for render instances something thats in the scope of V3? I thought there was a whole slew of things like that we were going to be able to get access to in v3.
xcaseyx wrote:ohh I see, is support for render instances something thats in the scope of V3? I thought there was a whole slew of things like that we were going to be able to get access to in v3.
Render instances are simply converted to Octane Scatter node. If you know Standalone that could make some sense. There is a need that indexes the some colors to scatter matrixes. It's my old request from Otoy. I'm hoping to see a good solution for this.
papillon
Anxiously waiting for the OSX build... :)
capacitycorp
Are there plans to implement the "Sub-Grid Detail" controls from TFD? a la Velocity displacement+Noise Intensity?
Testing so far has been promising, 3rd party controls have enabled for a lot of customising which is really positive.
TBA3D_70
So here is a wip alpha1 version. Currently it's just for windows version, soon i'll try to make a build for OSX.
Sounds great ! ... can´t wait :D
NVN
Hi Aoktar.
I've some strange Error's.
I cant UVW Mapping.
I deinstall all old files, installed the new Octane Standalone and the plugin also.
C4D R15.
Have i forgot something what i have to do?
NVN wrote:Hi Aoktar.
I cant UVW Mapping.
C4D R15.
No that's my mistake on compiling flags. I fixed and re-uploaded archive.
eyeonestudio
Asym93 wrote:I did a quick test with TFD. I have to say the integration is like magic. The plugin itself is explosive!
Amazing work Aoktar!
Congrats to the Octane dev team!
Could you share the Scene?
I want know voxel & tfd setting. :(
Thanks...
-------------------------------------------------------------------------------------------------------------- I found Something
C4D R2025 / Win11 / AMD TR WX Series / 256Gb RAM / RTX3090 / 100GbE
Return to “Releases”
