OctaneRender for DAZ Studio 3.02 [OBSOLETE]
Moderator: BK
Spot rendering or region rendering did not work for me though. It still renders the whole scene, however it reduces the samples like it is spot rendering.
Yes, I think render region if not working in the Octane 3 engine right now, but Otoy are working on it.
dustrider
Paul - I just wanted to say thanks for all your hard work, and taking over the development of this plugin (and thanks to t3 for all his hard work too). I had pretty much given up on it until you took over, and seeing that we already have a version using Octane 3, I finally upgraded from version 1, since plugin development is obviously very alive again. I just started playing with it tonight, and am quite happy with what I've seen so far. The stability and usability is sooo much better than it was before, and the Iray texture conversion is quite good as well.
Thanks again!!
papillon
Hi Paul any chance to make an OSX 3.0 test release?
gaazsi
very minor little bug occurs for me, pretty often. but not a real big deal.
whenever i start the render for the first time it seems that the lights arent calculated in (squares with emission in my case), after reload complete scene it works fine then. like i said, very minor :)
Veneris
Face_Off thanks for supporting the OC for Daz Studio.
Intel Core i5-2500 CPU @ 3.30Ghz (Quad Core), 12.0GB RAM, NVIDIA GeForce GT 620. Windows 7 (64 bits)
kibbycabbit
Thank you for making it possible alongside with OC Standalone timeframe.
I've experimented between object blur and camera blur.
It looks like camera blur only works. Is it possible to activate motion blur for the objects?
System #1: Mac Pro Early 2009, 12GB ECC RAM, Display: GTX 750 Ti 2GB (Maxwell) + CUDA: GTX 980 4GB (Maxwell)
System #2: MacBook Pro /w Retina 15", 16GB RAM, GT 650M 1GB
System #3: PC Windows i9 6 cores, 16GB RAM, RTX 2080 SUPER 8GB
It's on the list of things to do - but is not simple - so is going to take some time to get done.
ClairObscur
[Test] - Bugs Reports.
(Infos : Using DazStudio 4.8 Official (not the 4.9 beta))
- Problem to set manualy a focus to a point (the hand in the exemple)
- Sometime, i have to rebuild the scene or he do not restart the render
I will continue to test this new version.
Sincerly,
C.O
Intel Core I7-3770K | 16Gb Ram | Gigabits GTX 970 Overclocked 4Gb DDR5| SSD Crucial Adrenaline 64Gb | W7Pro 64bits | Octane 3.x + OCDS 3.x
Migrating the plugin to OSX is not a trivial task, so it's something I will need to do once I've got through the Octane 3 backlog (so two/three months)?
Ye - it looks like Focus Picking is not working at the moment. This appears to be related to when you export a scene to ORBX, the Octane camera focal distance, etc is not set correctly in the ORBX. I am working on it - but it will take some time to fix.
Return to “DAZ Studio”
