Crashes Node Editor
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
RahiSan
I have a lot of crashes when using the node editor.
They occur when I connect textures to materials or even when I connect them to a multiply, mix texture or anything of that sort.
I Run Cinema 4d R17 0.32. Win 7.
It happens on both of my machines.
Version?
RahiSan
I currently have test 5.1 on one machine and a version of test 3 on the other, it happens on both. Standalone 2.24.2.
I don't see this kind of problems. Please try test 5.2. Let me know the results.
RahiSan
I will do so and post here, thanks for your quick reply!
RahiSan wrote:I will do so and post here, thanks for your quick reply!
If you still see crashes, please give me some better info. Some video capture to show it. Also sample scene to allow me to check it. Thanks.
wuyue1990
A. macOS 10.13.2 17C89
B. GTX 1080 8GB N1080WF3OC-8GD
C. RAM 32GB
D. Nvidia driver version 378.10.10.10.25.103 & CUDA 387.99
E. no standalone
F. 3.07R1 & 3.07R2
G. C4D R19.024
H. node editor constantly freezes and not responding at all
I. pls see the attachment
C4DR19crashlog.rtf
(1.2 MiB) Downloaded 324 times
Hi wuyue1990,
it would be better if you could share a c4d bugreport.txt:
viewtopic.php?f=86&t=54503#p285380
How much free VRAM do you have while working with materials?
Have you enabled the Out-of-core option?
Is the Synchronize on geo update option disabled in Octane Settings/Others?
ciao beppe
totemstudio3d
After reading this bug report, I've found out that I'm not the only one getting the same issue. I had this same error and crashes since version 3, version 4 and the most recent 2020.2.4-R2 version over c4d S22 and R23, doesn't matter if the scene is complex or as simple as a cube with a basic material, it is completely unexpected. Sometimes it doesn't crash at all, and suddenly it does, one thing is for sure it always happens while connecting or disconnecting a material node, doesn't really matter which one, it just crashes. In may case cinema4d just freezes, and I have to "end task" cinema4d in the windows task manager. In some situations (many times), I can't even re-open c4d after the crash and eventually had to restart the entire computer in order to open c4d again.
I've previously use a GTX 11gb card and had the issue as well, now I'm using a RTX 24 gb and continue to have this random problem while working in my scenes. I can't believe it is a matter of the graphics card, specially when you are working with simple geometry and simple 1k textures, I understand when I have a massive scene composed with hundreds of assets and materials, but when there's nothing that should make the system to crash it is completely awkward and frustrating.
If there's just a preferences box I have to tick to avoid this annoying constant crashing issue, I more than welcome to hear any suggestions. I can provide any technical detail about my computer setup and I'm adding the latest bug report when it happened the last time I ran into the issue.
Thank you in advance
_BugReport.txt
(134.23 KiB) Downloaded 239 times
totemstudio3d wrote:After reading this bug report, I've found out that I'm not the only one getting the same issue. I had this same error and crashes since version 3, version 4 and the most recent 2020.2.4-R2 version over c4d S22 and R23, doesn't matter if the scene is complex or as simple as a cube with a basic material, it is completely unexpected. Sometimes it doesn't crash at all, and suddenly it does, one thing is for sure it always happens while connecting or disconnecting a material node, doesn't really matter which one, it just crashes. In may case cinema4d just freezes, and I have to "end task" cinema4d in the windows task manager. In some situations (many times), I can't even re-open c4d after the crash and eventually had to restart the entire computer in order to open c4d again.
Your bug report is not showing any crash in octane plugin. Do you have any other bugreport.zip from the moment of crash?
Return to “Bug Reports”
