modo > Octane / Export Script v1.01
stenson
Here's the first version of the octane export script for modo.
If you find a bug, please leave a detailed step by step description of how to reproduce the bug, a copy of the event log and your system spec.
Enjoy!
modo2octane_1.022_v1.01.zip
(58.9 KiB) Downloaded 700 times
Fredrik Stenson
http://www.stenson.tv
modo resource @
http://www.modo.stenson.tv
stenson
Screen Grab...
Fredrik Stenson
modo resource @
El Burritoh
Thanks Fredrik!
Could you explain again about how our scenes in modo need to set up to work optimally with this exporter?
sjogren
thank you, Fredrik!
were going to bed but had to start the computer and try it.
looks real nice, will try and play more later...
tack igen!
Windows 10 (64-bit) | GeForce GTX 1070 & 970 (416.34) | i7 6850K | 32 GB System Memory
Modo 12.1v2 | Plugin Version: latest beta 4
El Burritoh
Nevermind! I had a crash, but it was because I used spaces in my pathname.
Don't use spaces, just like he warned us!
El Burritoh
Any chance of adding an easy "Cancel" option for rendering animation? Since it runs a script for each frame, it completely takes over my machine and I have to manually crash modo to make it stop...
Otherwise, looks good! Still testing!
stenson
El Burritoh wrote:Any chance of adding an easy "Cancel" option for rendering animation? Since it runs a script for each frame, it completely takes over my machine and I have to manually crash modo to make it stop...
There should be a progress bar during animation rendering, the progress bar got an "abort" button. It will appear after the first frame.
cheers
Fredrik Stenson
modo resource @
stenson
i would like some help to really stress test the script.
test it as much as you can, then please leave a comment.
cheers
Fredrik Stenson
modo resource @
robk
Tried the script, The object got saved out with a mtl file. No camera position etc were saved out and no materials (uV'ed) came over either. I had also copied the images for the materials into the same directory as the OBJ file.
El Burritoh
How do we get textures to carry over?
Return to “Foundry Modo”
