v3 dev update
Goldorak
RobSteady wrote:Abstrax, have you seen the Altus Denoising System? Possible to integrate it directly into Octane?
I already wrote about it here: viewtopic.php?f=9&t=50948&hilit=Denoiser
We have done tests with it and it works well (so far) using the new info channels we have added in V3. Temporal denoising has been tested and seems to work well too.
Generic denoiser modules/plug-ins can be added to Octane 3 if they are based on similar techniques to this, Pixar's system or the published techniques out there, several of which we implemented as real time GPU filters for Brigade back in 2013 (these might be useful for Octane real time viewport, but not ideal for final render, which should be an offline job for best quality).
Direct integration of a final render denoiser is not going to work like hotpixel removal - as it takes minutes to denoise on a 32-core CPU machine, so you don't necessarily want that locking up the DCC app during a render. It can be implemented more easily as a post-render batch system, and a lua script node could drive the high level parameters.
RobSteady
Sounds good, whatever works!
This is a test with V-Ray and Altus Denoiser. 8 min rendering, 2 min denoise:
all images from Vlado, Chaosgroup
Octane for 3ds Max v2.21.1 | i7-5930K | 32GB | 1 x GTX Titan Z + 2 x GTX 980 Ti
gabrielefx
impressive...
Definitively every renderer needs this denoiser.
xcaseyx
the alpha thats going live, will license owners of 2.X get access to it?
MaTtY631990
Yep, it was confirmed 2x owners will be able to use the alpha and beta releases of V3.
sadece
It's gonna change the rules !
http://www.sadece.com.tr
i7 990x // 12GB Ram // 2x Titan X + Titan + 780 // Octane for C4D // Win7 x64
xcaseyx
It's thirsday!!!! Will they release this week?? Did they ship to partners on time? The world may never know.
coilbook
xcaseyx wrote:It's thirsday!!!! Will they release this week?? Did they ship to partners on time? The world may never know.
same here I've been waiting for octane 3 since march lol
I wonder how to create flames that can interact with objects. For example a burning building with flame and smoke coming out of the window. So far a saw only objects on fire. Can we use something like Phoenix FD for particle simulation and OCtane 3 will add fire over them?
brasco
Octane will render these fluid volumes but does not generate them, the browser demo above shows this, it loads VDB in and you apply a scatter volume to it. You can save out these VDB volumes from a few sources like Houdini.
cheers
brasc
Rig#1 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 7900K 4.7GHz | 64GB
Rig#2 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 3930K 4.4GHz | 32GB
Rig#3 Win 10 x64 | GTX 1070| GTX 1070| GTX 1070| i7 2600K 4.8GHz | 32GB
coilbook
cheers
brasc
Thank you! I hope PHoenix FD creates VDB volumes
