Render looks differnetly through deadline
Yambo
Hi all,
I've installed Thinkbox Deadline on my machine to manage my Octane renders. it seems to work but render looks a bit darker.
I'm submitting & rendering only on one machine. without any network related.
2 images attached. Darker image is the image that passing through Deadline.
Any ideas what can cause it? it doesn't seems like a gamma issue.
Thank you!
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
fuchsundvogel
i think its the same problem as here.
viewtopic.php?f=86&t=51036
NVN
are u using Multipass?
Liniar output?
fuchsundvogel
it has nothing to do with multipass. it gets darker when you use the camera imager and render with commandline.
what happen if you switch from Thin lens to Panoramic camera type in the Octane Camera Tag?
If the render is not panoramic, then the Octane Camera tag is completely skipped by deadline software I think :roll:
ciao beppe
fuchsundvogel
same behaviour
Yambo
Yes, same behavior here also.
What can i do? what people are doing? some users wrote here that they are using deadline successfully.
https://yambo.me
NVN
strange, sry i dont know :-(
maybe aoktar can help u...
Yambo
Ahmet? Someone?
It doesn't make sense that no one can help with it.
https://yambo.me
Yambo wrote:Ahmet? Someone?
It's related with a bug in version checking. Somewhat read wrong version value when you launch from command line and It modifies camera imager gamma value to adopt for old system. I'll fix it.
