Abort & other buttons disappear
One of my Macs has a monitor with a maximum resolution of 1600x900. If I try to render a large resolution frame requiring any zoom factor of 1:2 or higher the panel with the Abort & other buttons at the bottom of the render window disappears. This is causing a big problem for me right now.
Vote for Juanjo!
Can you please test this new custom build? It has a new options in the plugin options panel to reduce the size of the preview window, so now it switches to a lower size after reach less resolution. With this option enabled, you should be able to have always the full preview window in you 1600x900 monitor.
https://www.dropbox.com/s/prod4ddv271a4 ... n.zip?dl=0
That fixed it. Thank you very much!
Vote for Juanjo!
