That's a lot of shoes mate!FractalMotion wrote:you can watch it here : https://vimeo.com/143891948
I can't seem to turn on the particle engine.
scene?FractalMotion wrote:Oups sorry this is the picture with the Trail problem !
Oups !!! sure Aoktar ! here you go !scene?
It's my neglect. This parameter should be deprecated. You can use particle engine part in Octane object tag. If some spheres don't appear assign some custom objects to object list in tag. Standard particle emitter can have some stability issues.Gumz wrote:I'm sure I'm just a noob, but I can for the life of me not get Octane to render particles.
Could some kind soul run me through a basic setup?
I apply an object tag to an emitter and enable "Particle Rendering" in the tag. Shouldn't that be enough?
Octane won't let me check "Enable Particle Engine" in the options menu, neither in r16 or r17, so I figured that's not the issue?
Here's a standard emitter and an old X-particles 2 emitter (haven't bought XP3 yet) both with an object tag and custom objectsaoktar wrote: It's my neglect. This parameter should be deprecated. You can use particle engine part in Octane object tag. If some spheres don't appear assign some custom objects to object list in tag. Standard particle emitter can have some stability issues.
