OctaneRender® for 3ds max® v2.24.2 - 2.10 [OBSOLETE]
jblessing
I'm having problems with the render freezing up when a net render GPUs drops offline. Sometimes it keeps going, sometimes it just stops rendering on that frame even though it shows it is still rendering. It's done it on two different projects now.
Win 8.1 | 4.1ghz 5960x | Cinema 4D R20 / 3ds Max 2018 | 2 x Titan Z + 980
Win 10 | 3.0ghz 2697 v3 | Cinema 4D R20 / 3ds Max 2018 | 4 x 980ti hydros
4 x Win 7 | 4.0ghz 5930k | 4 x Titan Black or 4 x 980ti
Goldisart
Please include support for file paths in Cyrillic transcription LIVE DB
(inside textures 3D max support ways supported Cyrillic)
Phil_RA
Probably already mentioned:
I had the render viewport opened, I opened another scene and left the viewport opened, then came back to my previous scene, and now I can't close the render viewport at all, most of the buttons are gone too. I have to shut down Max to get rid of it.
Max 2014
gueoct
Phil_RA wrote:Probably already mentioned:
Max 2014
i can´t reproduce that. i just tried 4 max sessions with open Octane viewports, all of them work fine.....
Intel i7-970 @3,20 GHz / 24 GB RAM / 3 x EVGA GTX 580 - 3GB
bezerker75
We are trying to render a shot for a project and just noticed that when the object has no movement, for instance when we do a "hold" on the animation Octane renders the frames black. I know we can do this in post but why would this be happening? It renders fine in the VFB, just not when you do a production render. Is this a bug or is there some check box some where that ignores non moving objects? Anyone else ever have this issue? Thanks.
thilima
As you can see Octane Render is not recognizing the Render layer (more than value 1) on FOREST PRO, I tried to put Layer ID 2 on the scattered object too, but same result.
Thanks a lot guys and congrats for the latest updates
darkline
More information on the bug I posted earlier - the octane viewport constantly refreshing.
Come into another situation where it happens again. I have created some box geometry with animated noise modifier on top. Then Iv'e created a paricle flow with the box as an instanced object about 50 times. When I turn on vertex motion blur for the particle event I get the same viewport frefreshing bug.
If I turn 'autoupdate movable proxy' off, it stops refreshing and fixes the bug. Equally if I turn off motion blur it fixes the problem too. Renders turn out fine, but I cannot have 'autoupdate' and 'motion blur' on in my octane viewport
Windows 7 64bit/ Intel 3930K/ ASUS Rampage IV/ GTX980ti x 2/ 64GB system RAM
JimStar
Next version HERE.
Locked
Return to “Releases”
