Version 2.24.2-TEST6 - Test only
eyeonestudio
Can't render "closed spline". is default? :)
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
Propably. I'll take a look. This is test version and i'm adding dirty features in my todo list. So excuse for problems.
Elprezzy wrote:It is great stuff. Thanks Ahmet.
I love the scatter object, I only have broadcast r15 and have longed for a hair module..this is not it but creative use of this fills a gap. Pardon the pun. :D
Craig.
Ron wrote:This is great!
Thank you for fixing the layout bug: Now it's working for me and I can play with those awsome new features. Scatter is incredible!
I was thinking about buying Carbon Scatter but now I won't.
Thanks for your really outstanding work!
Ron
I would like to see what are you doing with scatter. It helps to improve more. As a note, scatter objects is not optimised for viewport or render time and works mostly on one core.
Thanks ;)
SephirothNP
Hi Ahmet- just wanted to say that I really liked the small touches you put in this release- specifically, when the LV window is resized and the image eases in to the new size. It gives it a really professional, almost Apple-like feel. Keep killing it man.
Falcon Mach V
i-4390k/32GB
GTX 780Ti
Nuge
Ahmet,
Firstly you have and continue to do an amazing job, keep up the good work!!
I do mainly arch viz renders and import the models from Archicad, problem is that i cannot control how the meshes are generated on the import process and i end up with meshes with varing sized polygons as per the attached file, this has not been too much of an issue until i want to cover the mesh with a grass object. I have tried various methods (Cloner,Carbon Scatter, Multicloner) but they all seem to use the polygon (centre/face/surface) to calculate the position.
I have just tried your scatter object and have run into the same problem, is there some way to distribute the objects in a more uniform manner without using the polygon data.
Regards Nuge
MESH TESTER.zip
(1.35 MiB) Downloaded 321 times
C4D R19 / Win 10 / 7 GTX 1080
martincarlson
The scattering tool is just AMAZING!
Good job! My biggest fears is that Ahmet will leave OTOY for someone else. You are doing an amazing job.
EDIT: A little test image attached.
Last edited by martincarlson on Fri Oct 16, 2015 12:49 pm, edited 1 time in total.
Martin Carlson, Visual and Audial Designer at Katzenwaffe Creative Studio | www.katzenwaffe.se | Soundcloud | Twitter
Intel Core i7-5930K / ASUS X99-E WS / 2 x EVGA GeForce GTX TITAN X 12GB / 32 GB RAM / Windows 10 / C4D R16 / Octane Standalone 3.03.3 / OctaneC4D 3.03.3-R1
Nuge wrote:Ahmet,
Regards Nuge
Thanks for words! About your issue, Scatter is actually capable to do what you want. But i suppose it's not working well on Test2 due lot of playing with codes. Here is a result for you.
martincarlson
If there is any way to implement any performance-filters like Camera culling, Backface culling etc - that would be awesome. Like SurfaceSpread.
Octane Scatter has good possibilities to beat SS. I already think Scatter is better. :)
martincarlson wrote:If there is any way to implement any performance-filters like Camera culling, Backface culling etc - that would be awesome. Like SurfaceSpread.
Yes, it's on my list. I loved the your render test also. Btw, i'm adding direct support for Surface Spread and Laubwerk plants. I don't want to beat some other products. It's faster because it has direct access to generated data.
mustardseedsg
aoktar wrote:Btw, i'm adding direct support for Surface Spread and Laubwerk plants. I don't want to beat some other products. It's faster because it has direct access to generated data.
YES!!! That's the best thing for Octane: to play well with all possible native features and plugins.
Mac OSX 10.12.6 / MBP 15" w Touch Bar, 16GB / Mantiz Venus Thunderbolt 3 enclosure with GX1080 / C4d r19 Octane
Return to “Releases”
