sure, can i send it via pn? its kind of a confidential project.aoktar wrote:No. It's a global parameter. I'm not sure why it happens in just LV. But it's exactly related with RenderShader. You can test it by removing C4D shaders. Also maybe good to share some scene with me.
Application and Plugin Error
MacPro5,1 OS X 10.10.3 | GTX TITAN Black, GTX 970, 3x GTX 780Ti, GTX 780
						Sure PM. But please try first your self as i described.skoeth wrote:sure, can i send it via pn? its kind of a confidential project.aoktar wrote:No. It's a global parameter. I'm not sure why it happens in just LV. But it's exactly related with RenderShader. You can test it by removing C4D shaders. Also maybe good to share some scene with me.
Okay thanks, i tried - for a moment it seems that deleting some noises will make it but it seems like its just taking some more time until it crashes again.
this is so weird especially because it was working just like that last week.
i will send you the file via pn, really appreciate your awesome support!
						Just try to go back to version 2.23.2. I had a tone of crushes / errors / problems. Since ive reverted to version 2.23.2 everything running smooth.
							4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD  |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0
https://yambo.me
https://yambo.me
That's not logical without comparing.Yambo wrote:Just try to go back to version 2.23.2. I had a tone of crushes / errors / problems. Since ive reverted to version 2.23.2 everything running smooth.
i'd wish it was simple like this but it's still causing the same crash with that version.Yambo wrote:Just try to go back to version 2.23.2. I had a tone of crushes / errors / problems. Since ive reverted to version 2.23.2 everything running smooth.
						okay i think it has something to do with the c4d layer shader.
usually it works, but when there is a c4d noise in it there might be some issues.
i can't reproduce the crash in a simplified setup tho, but my scene is working now when i deleted the layer shaders.
