OctaneRender 3 for Revit [OBSOLETE]
Autodesk Revit (Integrated Plugin developed by Paul Kinnane)
Garquitectos
I hate you!!! ;) Every week new version and now you make that i need to buy phantom photo match... It's a joke! Many thanks! you are the best developer that I know. :D Downloading
Octane Render for Archicad, Archicad 16 Spanish, Bimx. - Win 7 64 bits - Intel core i7 870 - 3,30 Ghz, - 12 Gigas Ram - GTX 660 + GTX 650 Ti
http://www.garquitectos.es
http://garquitectos.wordpress.com/
Garquitectos
Important bug!
With the octane plugin installed when I link a IFC it doesnt work. After this window when I load the ifc it doesnt appear.
Windows with the error.
Can you pls send me an IFC file which demonstrates this problem.
2.24.2.35
- Compiled with Octane 2.24.2
- Fixed issue where loading an IFC file would raise an exception. Because Revit triggers a "New Scene" event when loading an IFC file, load an IFC file will cause the Octane Viewport and Setup windows to close
Garquitectos
Many thanks Paul!
3.0.0.36
- Compiled with Octane 3.0.0
- Added Medium and Medium Radius to the Daylight and Texture Environment settings
- Added new Render Passes
- Removed "Ambient" and "Sample Environment" GI Modes from the Direct Light kernel
- Added Deep Image settings to the kernel settings
- Added support for VDB files (add them in proxy ORBX files)
* If your default rendertarget has Render Passes->Info After Beauty ticked, I suggest unticking it and re-saving your default rendertarget
KNOWN ISSUE: If you pause rendering, change an Octane setting, then continue rendering, the Viewport will freeze (and you will need to refresh the scene to restart the Viewport). This will hopefully be fixed by Otoy in the next release of the API.
As this is the first Octane 3 build of the Revit plugin, exercise caution and keep backups of the 2.24.2 versions of your scenes.
Seekerfinder
Awesome! Will give it a go ASAP, thanks Paul.
Seeker
3.0.1.37
- Compiled with Octane 3.0 alpha 2
- Added Baking Camera. All geometry in the scene will have the same baking group ID, so this function will be of limited use to Revit users.
- Manual updated with Octane 3 features. Pls see https://docs.otoy.com/Revit/?page_id=643 for details.
Garquitectos
is it posible to match focal distance between Revit and Octane?
I usually change the distance focal inside Revit and in Octane it doesnt change.
Many thanks.
Are you referring to Focal Length or Focal Depth (they are different pins on the Octane camera)? How are you changing this value in Revit?
Return to “Autodesk Revit”
