This feature will help to realize the sea and endless horizon territory
with support for bump and displacement
please add Infinite Vray plane
- Elvissuperstar007
- Contact:
- Elvissuperstar007
- Contact:
we tried to do in octane sea under the boat, we did not have enough memory)roeland wrote:The easiest way to achieve that in Octane is adding a large ground plane as geometry in your scene.
Roeland
I think you're right about the displacement, it doesn't work well on huge geometry. It didn't run out of memory in my test case though, can you post what exactly happens if you try to render that water surface, and how you modelled that surface?
Roeland
Roeland
- Jolbertoquini
- Contact:
If you have a small plane tiled displacement and repeat as instance scatter you my have the sea I did here for one project and was working totally fine. in (baked geometry alembic)
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
- gabrielefx
circular poly
lod on displacement
et voilá.
lod on displacement
et voilá.
- Elvissuperstar007
- Contact:
in 3DS Max is not very convenient to work with large objects in a couple of kilometers, everything begins to show artifacts
