Sorry this new one gives this error when looking for App
// Error: Cannot find procedure "fileDialog2".
Peter
Latest version location
Moderator: JimStar
- p3taoctane
ill upload the page with plugins, get it from there
what maya ver u use?
plz people write down the maya ver, coz its not the same from ver to ver!
Maya 2009 x64 & Maya 2011 x64
Windows 7 x64 & Windows XP x64
2x Quad Core Q6600, 8gb, Nvidia Gtx 260 & Gtx 460
I always just rename my octane binary "octane.app" to avoid spaces. I never used it with spaces in the name but it should be addressed by the plug in - adding escape characters. Otherwise, I'd just recommend to Terrence to just keep the binary as octane.app and if you need to keep different versions for betas, do octaneb22.app etc.
- p3taoctane
Maya 2010 did not work with spaces
and Maya 2011 did
Sorry should have mentioned I was in 2010
and Maya 2011 did
did u try new ver?
i made some small changes with spaces, so now it doesn't matters where the octan render is, and if there r or not spaces in the path location
- p3taoctane
Yep I tried with new version. Works with 2011 . Not with 2010.
Peter
Itscan easy work around so I'm not worried. But happy to help test more if you would like
Peter
well that would be nice if u have spare time, only probl is that i dont know what went wrong in maya 2010 osx
im using win only (so far) so i can confirm that everything here work 99%
only way i could also test the probl is to somehow install osx...
cheers
cheers
- p3taoctane
I'll poke around some more. It's areal robust script. You've done a great job.
Will let you know if I find anything. Mine works fine on 2010 in windows too... So its definitely a Mac issue.
Time for you to bulid a hackintosh from an older pc : > )
On a different issue... I could put this on a different post if you like.
On windows 7 Maya 2010 is the gpu count for two cards 1 ( zero and one) or two for two cards?
Kinda Dumb question... But i am checking to see if i am getting errors on my dual cards freezing or if it's coming from that number causing an issue.
Peter
Peter
