Is there a way to smooth polygons in Octane?
Tigersan
Poser has a feature called smooth polygons that rounds up the mesh if it's low resolution.
It seems Octane doesnt have such option. Or does it? Is there an option to smooth polygons?
My Artstation profile: https://www.artstation.com/tigersan
Software: Poser 11 Pro, Octane Studio 2020.1.5.104, Adobe Suite
My RIG:
Operating system: Windows 10 Pro 64
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
HDD: 2x WD Gold 7.68TB U2 NVME
You can turn smoothing on/off at the material level (see question 1 in the FAQ https://docs.otoy.com/#44FAQ and https://docs.otoy.com/#44Glossy%20Material). Or you can subdivide the mesh (either in Poser or Octane) - see Subdivision at https://docs.otoy.com/#44Octane%202.0%20Features.
Tigersan
Only thing i have in my materials is "smooth" but i have it enabled and it doesn't do anything... :/
There's no such thing as "Normal smoothing" neither in diffuse node or glossy.
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
wimvdb
Smooth does work with enabling smooth in each material
It does not do it as good as Poser, but in Octane you can turn on subdivision and it will look better
See attached pictures
Without subd
With subd
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
Normal Smoothing = Smooth. Also, make sure Setup->Smooth Default is ENABLED.
If you could post a screenshot of your prop we can get a better understanding of the smoothing issue you are having.
Return to “Poser”
