Flickering reflection on phone lens render
jingles
My phone render has a flicker in the top glass lenses. The main source of this issue is because the phone has Dynamics enabled to add a more natural movement as it re-positions. I've tried tweaking Octane settings to remedy the flicker AND dynamic settings to ensure it has stopped fully but without luck. The wireframes are buzzing ever so slightly so i can tell there is slight movement, though its not visible on screen.
Hoping someone can help.
Octane Settings;
- Tried Direct Lighting and PTrace with multiple diffuse/spec/glossy depths from 3-6.
- Increased samples
Dynamics:
- Linear velcoity Threshold: 15cm
- Angular velocity threshold: 25 degrees
- Mass Density 5 / Rotational Mass 50%
- Force Follow POS: 30
- Follow ROT: 20
- Linear Damping 50%
- Angular Damping 25%
Phone-MoveALL-6_Dynamic2 crop_web.mp4
note glass lens flicker
(1.75 MiB) Downloaded 2218 times
tcollier
Hard to tell from your video but it looks like you need to use the hotpixel removal setting.
eyeonestudio
Too Big Scene Scale?
Need More Value --> Ray Epsilon
Nearest Surface ?
Duplicated Object?
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
jingles
eyeonestudio wrote:Too Big Scene Scale?
Nearest Surface ?
Duplicated Object?
Thanks for the replies...will try hot pixel.
Not sure about scene scale...Objects are about 160 cm / units and project scale is 1cm.
What do you mean by nearest surface?
Any tips on approaching Ray Epsilon values?
