Any idea on when we'll see a new version Paul?
Cheers!
The render artifacts are fixed in SP2, however there are still other issues (functional and stability), so I don't recommend using it yet.Hopefully all those nasty bugs related to the rendercache should be gone.
The latest version of the plugin works with SP2. No need to wait.alright, waiting for your new version.
This will make proxies and reference meshes work? Even with Octane overrides? I didn't know that.face_off wrote:Raf, SP2 resolves a lot of issues in Modo generally, and with the Render Cache API, so definitely worth updating to it. However there are still issues with the Render Cache, so leave it UNTICKED in the preferences (unless you specifically want to render the Modo Hair Shader, or proxies, references meshes, etc).
It /should/ although there are some limitations. https://docs.otoy.com/#42Modo901%20SpecificsThis will make proxies and reference meshes work? Even with Octane overrides? I didn't know that.
