SP2 is out!!
Rafael-Vallaperde
Hopefully all those nasty bugs related to the rendercache should be gone. :D
Any idea on when we'll see a new version Paul?
Cheers!
Rafael-Vallaperde
Fix list:http://community.thefoundry.co.uk/support/MODO901_SP2_details.aspx
The render artifacts are fixed in SP2, however there are still other issues (functional and stability), so I don't recommend using it yet.
Rafael-Vallaperde
alright, waiting for your new version.
Cheers
The latest version of the plugin works with SP2. No need to wait.
Rafael-Vallaperde
But you mentioned that errors might be preset. should i wait for a SP3 then?
Sp2 resolves a lot of modo issues!
But if it start to cause me issues with octane i rather wait.
Raf, SP2 resolves a lot of issues in Modo generally, and with the Render Cache API, so definitely worth updating to it. However there are still issues with the Render Cache, so leave it UNTICKED in the preferences (unless you specifically want to render the Modo Hair Shader, or proxies, references meshes, etc).
Rafael-Vallaperde
Sweet, thank you for clarifying Paul!
LFedit
face_off wrote:Raf, SP2 resolves a lot of issues in Modo generally, and with the Render Cache API, so definitely worth updating to it. However there are still issues with the Render Cache, so leave it UNTICKED in the preferences (unless you specifically want to render the Modo Hair Shader, or proxies, references meshes, etc).
This will make proxies and reference meshes work? Even with Octane overrides? I didn't know that.
Win 10, Threadripper Pro, Dual 3090s
It /should/ although there are some limitations. https://docs.otoy.com/#42Modo901%20Specifics
Return to “Foundry Modo”
