Post Effects Glare and Alpha
- aggiechase37
I can get the post effect glare to show up when I have an alpha going in the live view, but when I render a final to picture viewer, the glare streaks don't seem to make it. I use the copy to video post command, and everything else carries over, but that one effect. What am I missing?
Chase
Win 10 - Intel 4770 - 2x Nvidia 1070 - 32 gigs RAM - C4D r16
http://www.luxemediaproductions.com
The alpha mask is cutting the effect, but you can activate in the multipass tab the post-effect as separate layer, so you can compose it later on.
ciao beppe
ciao beppe
- aggiechase37
So I tried doing that but I'm guessing I'm missing a setting because what's going on in my image sequence files, doesn't seem to translate to what I want when I throw them into After Effects. Project file attached. Thanks in advance. I really do appreciate.
- Shahidrah.zip
- (109.99 KiB) Downloaded 249 times
Chase
Sorry, I must have been more specific.
Not the c4d multipass but the octane multipass: try with this scene: ciao beppe
- aggiechase37
That works great. Thanks so much!
Chase
- aggiechase37
Well. I thought it worked great. But question. Do the post effects output not come with an alpha channel? I was wanting to overly this text over some footage with the light glare. Is there a way to get an alpha channel with the post light glare out of Octane?
I realize that I can take an alpha from luminance in After Effects, and now I've created a preset with the proper curves adjustments before and after the effect, but that's extra buttons that I have to press
Also, before anyone tries to get cute like me and render out EXR files instead of PSD, EXR files don't seem to work. PSD does. I don't know about other file formats.
Chase
- prodigiosovolcan
Hello, I'm trying to use the post effect over a transparent background, but as there is no alpha channel into the post effect pass, I can't make it work properly in After Effects.
Is there a way to get the bloom&glare effect with transparent background so I can export that as a PNG with alpha?
- jayroth2020
Post Effects are additive; there is no alpha created for the post effect pass. The best you could do would be to use the pass as a luma matte in AE, though I doubt it would look natural.
