Jim,
Any chance you can make material export for old octane material that works with Max Multi/Sub object?. I have quite complex material set-ups in old octane with 10 or more material IDs. I can not export them to your new version.
thanks
OctaneRender® for 3ds max® v2.23.2 - 2.8 [OBSOLETE]
Hi, you can detach them by material IDs with this script:darkline wrote:Jim,
thanks
http://www.scriptspot.com/3ds-max/scrip ... aterial-id
*make sure you have the "propagate materials" option checked.
then select all of them and run this script:
get current selection and export octane materials one by one
currentSelection = #()
for i = 1 to $selection.count do
append currentSelection $selection[i]
for i = 1 to currentSelection.count do
select currentSelection[i]
actionMan.executeAction 982383860 "2169"
)- Elvissuperstar007
- Contact:
Converter does not work
Vray, Mental ray gives all white
3ds max 14-16, forest pack 4.4.1, octane 2.23.-2.8
Hey Elvis,
That is because a texture named ForestColor is not supported.
It is Forest Pack's own texture.
That has to be implemented in Octane no arguments there.
But. in order to get response, You have to ask for this feature in other topic under 3dsmax.
AFAIK this topic only accepts bug reports.
If you do that I'll also post for this feature.
EDIT: I am sorry for the above comment Elvis I've just saw that you have already made request in user request section.
The problem is Jimstar doesnot own any plugins. Somehow Otoy doesnt or wont buy a license for plugin developers.
Some how Karba had Forest pack and Jimstar doesnt.
And it's utterly sad and insane we come up with roadbloks in these cases.
My Portfolio
- Elvissuperstar007
- Contact:
Thank you very much for your answeroguzbir wrote:Hey Elvis,
currently in octane these plugins is useless
Elvissuperstar007 wrote: Thank you very much for your answer
The problem I see is that Octane Standalone core does not have a Random Bitmap support in it.
And without it I think nothing much can be done in plugin developing. So this is not a thing we can ask from Jimstar.
We must ask for this from the Standalone devs first.
My Portfolio
Hi Jim,Changes of the 2.6 version
Implemented the native 3ds Max BitmapTex support as the alternative input for Octane Image textures. You can use the Viewport Canvas now to draw "on the fly" on the Octane textures.
I'm having a pretty hard time grasping the concept of native BitmapTex support added in 2.6 version.
I guess that native "BitmapTex support " mean that it now the octane plugin understand the bitmap and enables to let the Viewprt Canvas to set the painted texture in RGB Image texture.
As I understand it does not mean that we can use Standard's bitmap texture as a texture in a Octane diffuse material.
So it's rather an internal thing.? Or are there other places we can make use of it?
Best,
My Portfolio
- Elvissuperstar007
- Contact:
Forest Pack 4.4.1 working Octane Render 2.23.-1.9oguzbir wrote:Hi Jim,Changes of the 2.6 version
Best,
- MustafaKaya
- Contact:
