Animation rendering in background - computer not useable
Micha
during rendering an animation per Bongo|Octane in the background the focus to the foreground software is lost every new frame is started. For example during I write this post here I need to click on the writing field again and again every view seconds. So, it's not possible to use the computer during the animation is calculated. Please fix it soon as possible since I need to render a lot of animations and I would like to work on my machine in this time.
Ciao,
Micha
PS: I posted this question at the McNeel side too, because maybe the Rhino team can help here too. But maybe it's only Octane plugin related.
http://discourse.mcneel.com/t/animation ... able/24177
http://www.simulacrum.de - Visualization for Designer and Architects
Win7 64 | Dual Xeon E5-2687W | 32GB RAM | 2 GTX 780 6GB | Rhino3D
Does this happen for you when you render a sun study too? Or just with Bongo animations?
Micha
At the moment a sun study is calculated and there is no problem to write here. So it seems to be related to Bongo.
(Only I don't see a sun study effect at the animation, but I never did a sun study before, maybe I did something wrong. But I get frames rendered by Octane.)
Micha
I did a test and the Rhino renderer shows the sun study. Is there a trick needed for Octane? How to link the Octane sun to the Rhino sun? The Octane sun option shows a fix direction always.
Micha
The sun works if I use the Octane viewport and edit the sun properties, but not if I start a sun study animation. At the animation is one sun state shown only.
Micha
PS: Your docu links doesn't open the pages, manually I can find them.
This is an example of how it works.
sun study.zip
(38.65 KiB) Downloaded 318 times
They work fine for me using Firefox.
Micha
Very strange, your file works, but not my setup. Attached my file.
At google chrome your links show the start page always.
SunStudyNotRunning.zip
(45.81 KiB) Downloaded 301 times
The links are working fine on Chrome for me. I suspect you still have the sun turned on - you need to turn it off.
Micha
Great, got it, turned the sun off for the sun study. :)
You could add a note at the Octane sun that sun and sun study are independent, f.ex like this "for sun study animation be sure to disabled the Rhino sun".
Thank you,
Micha
Return to “Rhinoceros 3D”
