Render skipping frames issue
CCIDgfx
The issue is skipping frames while rendering. I'm sure it's a setting somewhere. This is a fairly new computer with all new parts.
3D Motion Graphics Designer
Intel i9 13900K / 128gb DDR5 / 1 Nvidia 5090 FE / PSU EVGA 1600w / WIN 11
CCIDgfx wrote:The issue is skipping frames while rendering. I'm sure it's a setting somewhere. This is a fairly new computer with all new parts.
Which frames are skipping? Can you show me a screen with picture viewer history? We have some debugging options to check it.
CCIDgfx
It's still happening and I'm on a pretty tight deadline to finish this project an I have to keep restarting my renders.
CCIDgfx wrote:It's still happening and I'm on a pretty tight deadline to finish this project an I have to keep restarting my renders.
you have two option to get my help, please choose one:
1-Describe very well the scene content and render settings.
2-Send me the scene to check
CCIDgfx
Here is the scene I'm trying to render
Candy Bin_All_0001.zip
(5.48 MiB) Downloaded 178 times
Thank You
CCIDgfx wrote:Here is the scene I'm trying to render
Thank You
I'm checking. On which frame does it start to skip frames? Is it happening after a spesific frame? Also what's your driver version?
CCIDgfx
I have the latest Nvidia drivers and I'm using the latest version of Octane plugin.
It usually does it around the 7th or 8th frame. It will do it twice then I can get it to go for a bit longer. But I can never render a full scene without the skipping frames.
CCIDgfx wrote:I have the latest Nvidia drivers and I'm using the latest version of Octane plugin.
I have tried to test it. Working as expected. I suppose there can be a problem on Renderer side as a crash or Cuda error. Have you checked the Script->Console output or LiveViewer->Help->Octane Log after this skipping happened? Anyway i'll try to check more to see somethings.
CCIDgfx
I'll check those next time it happens and post the log for you to look at =)
Thank You
CCIDgfx
Here are the log files for the most recent skipping issue
octane 2.24.1 150926 170055.log
(9.91 KiB) Downloaded 143 times
