Dirt: ignore bump setting?
Hey, is there a way for the dirt shader to ignore bump maps? I just want it to be applied to geometry regardless of the bump map applied.
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
- gordonrobb
Not sure I understand the question
exactly =) use mix material! that should help =)
when you apply a dirt shader it gets applied in the crevices of your bump map as well as the geometry, which you may not want.gordonrobb wrote:Not sure I understand the question
Aren't you also blending all channels though with a Mix material? So I can't get 100% of the diffuse of mat1 and 100% of bump of Mat2. I'd only ever get a proportion of each, eg 50% of the dirt darkness and 50% of the bump (or 80/20, 70/30 etc).glimpse wrote:exactly =) use mix material! that should help =)
you can use same texture in both material, also possible to use a multiply node with floattexture>1.0 to exaggerate the bump effect.sdanaher wrote:Aren't you also blending all channels though with a Mix material? So I can't get 100% of the diffuse of mat1 and 100% of bump of Mat2. I'd only ever get a proportion of each, eg 50% of the dirt darkness and 50% of the bump (or 80/20, 70/30 etc).glimpse wrote:exactly =) use mix material! that should help =)
Float >1 is a good tip. I'm finding bump maps difficult generally though, switched to Normal maps.
