Render layer pass: Shadows. How can i get it????
AlexMakhov
How can i get pass Shadows? I have white image when select Shadows chanel in octane viewport
Shadows
Shadows
Beauty
Beauty
gueoct
Me, too, i only get a white image!
What is it with the Shadow Render Layer?
Intel i7-970 @3,20 GHz / 24 GB RAM / 3 x EVGA GTX 580 - 3GB
jim99
I cant seem to get a simple pass either ? Can someone help explain the process of getting a shadow pass pls :|
gueoct
Please! i really don´t quite get how it works.....
You need to enable Kernel->Alpha Channel for the shadow passes to work. https://docs.otoy.com/#51Render%20Layer%20Passes
jim99
Thanks Paul, But how do you do it in 3dsmax octane plugin ?
JimStar
The same as in standalone.
You assign the different render-layers to objects of interest.
Enable the render layers and set the needed active layer (what exactly - depends on what result you need).
Get some result.
Change the active layer if you need the different result.
HHbomb
Thanks Jim for explaination. :-)
Hopefully octane is real time, so we can test easily different parameters.
jim99
Thanks for this very useful indeed :)
Return to “Autodesk 3Ds Max”
