Is it possible to use a background with jpeg sequence in octane render and octane render plugin ?
I want to use a background "material" like I do in C4D standard renderer.
background animated like C4D
You can use it as reference but it will not render.
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0
https://yambo.me
https://yambo.me
Hi Yambo, not completely correct. It should work as in C4D's normal workflow. But can't be rendered out in floatbuffer type if i remember correctly.Yambo wrote:You can use it as reference but it will not render.
- bertritude73
ok. So there's no possibility to use an animated background for a tracking 3D text integrated in a video.
bad news for me...
bad news for me...
it's working with at least 8bit buffer. what's your real purpose? you can combine any background in compositing software when you choose floatbuffer.
Didn't know that, good to know! thanks.
https://yambo.me
https://yambo.me
- bertritude73
Sorry Aoktar, I'm a newbbe in this world and I don't understant what you explain.
I use a jpeg sequence in 8bit in a background material. if I use the first frame only, the background appears in octane render but if I specify in animation tab, all the frames, the backgroung is black again.
can you explain me how to do ?
Many thanks for your help
Nothing is different from normal method. You might be doing something is not supported. Attached a sample scene.
- imageseq.zip
- (441.32 KiB) Downloaded 393 times
- bertritude73
- bertritude73
Anyone can help me to find a solution please ?
thanks
thanks
