Cooldown 52 mins...
sdanaher
If its not one thing its another.
I need to get both copies of Cinema running with Octane, just like it always has. Now when I deactivate on the web I get an error saying I have to wait 52 min before I can reactivate.
I need to work.
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
sdanaher
Its not letting me run Octane in two instances of Cinema on the same machine.
What is the procedure to get it working without being locked out for another hour
garytyler
Are you using the "-parallel" command argument? Aoktar told me this trick for rendering in one instance and working in the other. I can even render in one instance and run live viewer in my second instance with my 5960x and 5 overclocked 980ti.
Win 8.1 / C4D R16 / Maya '16 / 5x GTX 980 Ti
sdanaher
No, i've never had this problem before. In all the previous versions I could run multiple instances of cinema no problem.
it shouldn't be version related. I run many versions same time. try again after a while.
sdanaher
Still getting the 'its activated on another machine' error in R16.
It's running in R17, and I don't want to risk breaking that again.
You can deactivate from Account page from this site. Will run after operation.
Yambo
Ahmet, can you give please some short explanation on how to run 2 instances on cinema and render simultaneously?
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
Yambo wrote:Ahmet, can you give please some short explanation on how to run 2 instances on cinema and render simultaneously?
All you need is to add a "-parallel" parameter to "CINEMA 4D.exe" when you run it. I can do it easily from my old friend "Total Commander". Also you can use a "*.bat" file to run C4D or any other method. You can run many copies of C4D at same time.
Yambo
Awesome works thanks.
https://yambo.me
