OctaneRender 2 for ArchiCAD [OBSOLETE]
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
zahi
Hi Paul,
Thank you for your reply.
Problem Solved.
Zaheer
Zahi
Win10 Pro| ASUS X99-E WS| EVGA TITAN X OC| 32g Ram| i7 5820k 4.0GHz
I have refreshed the STABLE installer downloads at the top of this thread to release 2.23.2.51 (the current TEST build). Pls see the TEST thread for release notes.
rappet
Hi Paul,
Just got into installing Archicad 19 and also the plugin.
The plugin works fine, but I noticed the add-on notification?
greetz,
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
Hi Jeroen - that is the status text for the OpenGL addon, not the Octane addon. If you select the OctaneRenderForArchiCAD_Renderer addon, what text is displayed pls?
rappet
face_off wrote:Hi Jeroen - that is the status text for the OpenGL addon, not the Octane addon. If you select the OctaneRenderForArchiCAD_Renderer addon, what text is displayed pls?
Oops, brainfailure :oops:
New one here.
New one here.
Thanks Jeroen. What build of AC19 are you using pls? Is it possible you installed the AC18 version of the plugin into AC19? If so, you need to install the AC19 version.
rappet
New one here.
I am almost sure I did install the Ac19 version...
I will check (also build) (my) tomorrow :-)
Also, make sure your plugins are being loaded from the AC19 folder.
rappet
Hi Paul,
Checked, even reinstalled, but the same.
(The plugin works though)
greetz,
What build number of AC19 are you using pls?
Return to “Graphisoft ArchiCAD”
