Poser eye color diff than Octane Render
morphious2013
No matter what color I change her eyes to, they always render blue in Octane. Any Ideas? Refreshed poser textures, and octane but still the same.
Using Plug OctaneRender_for_Poser_2_23_1_48_Win64
See attachments.
P.S. Don't know the hell is going on with the forehead.
Gateway i5 3.2ghz, 16g RAM, GTX 690 4GB VRAM, Windows 10 64bit, Poser Pro 11, DAZ Studio Pro 4.9, Daz Octane Plugin V2, Poser Octane Plugin V2
TRRazor
The problem you're having lies in the material set-up of the eye.
Check the Opacity node of the Iris, the Sclera or the Eye Surface, there should be a transparency map sitting in one of these, which is there to emulate the environmental reflection in DAZ Studios 3Delight rendering engine.
Since OctaneRender is a physics based unbiased rendering engine, those maps are not needed, since everything surrounding your character will reflect physicallly correct in the eyes.
Simply turn that Greyscale Image into a Greyscale color setting the value to 1.0 -that should fix your problem :)
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
morphious2013
There isn't an Transparency node with a texture attached. it is set to 1 already. and set to greyscale color.
What is your ray epsilon set to pls?
TRRazor
Unless you have a very sharp HDRi as your scene environment in that screenshot, the reflection in the eye is too sharp to be a physics-based reflection and rather looks like a map.
Another material you could check would be the Pupil. The fact that the reflection looks like a "sticker" supports my suspicion...
Otherwise could you please post a screenshot of your Iris / Pupil / Sclera and Eye Reflection material, so we can find and solve the problem?
Thanks! :)
Return to “Poser”
