Hi All,
Is it possible to create a setup like this using a old MacPro (1st Gen) box?
KJ
Mac + eGPU
What do you mean by "first gen"? Can you give us a model number? There have been at least five generations of the mac pro.
Download my free Octane resources!
Paper Lantern | Fresh Snow (C4D Only) | Keyboard Displacement Texture | Solar Panel Texture
Mac Pro (2012) | 2x6Core 3.06GHz | 64GB | 1 x Titan Black 6GB
Portfolio: http://www.deltawavefx.com
Yeah, thats pretty old. While you could definitely do it, I wouldn't recommend it. You do need a decent CPU as well just for the export from your 3D package to Octane. I have a 2012 Mac Pro and made sure to get the best CPU it could get, then replaced the GPU with a Titan Black and stuffed in an external psu that fit inside one of the DVD drive bays (so its technically an internal psu now).KevinJ wrote:
MA356*/A MacPro1,1
I don't intend to use it as my main machine, just use the box to hold nvidia cards.dotcommer wrote:Yeah, thats pretty old. While you could definitely do it, I wouldn't recommend it. You do need a decent CPU as well just for the export from your 3D package to Octane. I have a 2012 Mac Pro and made sure to get the best CPU it could get, then replaced the GPU with a Titan Black and stuffed in an external psu that fit inside one of the DVD drive bays (so its technically an internal psu now).KevinJ wrote:
MA356*/A MacPro1,1
Ok, then you could probably do it. I don't think it'll hold too many cards though. Even with an external PSU, I think you'd probably only be able to fit one or two modern GPUs in it. You'd probably be better off with an eGPU at this point.
dotcommer wrote:Ok, then you could probably do it. I don't think it'll hold too many cards though. Even with an external PSU, I think you'd probably only be able to fit one or two modern GPUs in it. You'd probably be better off with an eGPU at this point.
Thanks for you input.
Will it be an issue having mixed GPUs, AMD from the stock nMP and those from the eGPU?
KevinJ wrote:Will it be an issue having mixed GPUs, AMD from the stock nMP and those from the eGPU?
Nope, shouldn't be an issue. I'm doing that right now. Its honestly the only benefit to holding on to the default AMD card that apple throws in. Allows you to render the OS on the AMD card, and then set Octane to use 100% of the NVIDIA cards. Works out real well. I can have a full render going and still browse the internet or watch streaming video content without any issues. Just be sure you plug your monitor(s) into the AMD card, so the OS knows which one to use for OS rendering.
Thanks again. Looking at getting GTX 980s. Maybe one to start.dotcommer wrote:KevinJ wrote:Will it be an issue having mixed GPUs, AMD from the stock nMP and those from the eGPU?
KJ
- MarioVisuals
Hi Guys,
Does anyone have step by step instruction from you tube video which Jose did last year.
Video is no longer available on his you tube channel.
I just got all necessary parts but I need a guide to make it work on Yosemite.
Windows 10 Pro 64-bit / Intel Xeon E5 v3 @ 2.40GHz x 2 / 64 GB RAM / Z10PE-D8 WS / 3 x EVGA GTX 980Ti / C4D R17 / X-Particles 3.5 / Octane 3
