SoftImage XSI Plugin v1.022c
face
New Version of the Addon available.
Fixed:
Deformation bug.
http://www.refractivesoftware.com/forum ... =29&t=2477
Thanks to Chris_TC
Added:
Scene Viewport refresh.
Octane2Softimage_2010.zip
The addon for Softimage 2010 & 2011
(445.64 KiB) Downloaded 507 times
Octane2Softimage_7.zip
The addon for XSI 7 & 7.5
(446.5 KiB) Downloaded 485 times
Octane2Softimage_6.zip
The addon for XSI 6
(398.53 KiB) Downloaded 442 times
http://vimeo.com/user2509578
Chris_TC
It works indeed, you did it again! Thank you
Chris_TC
Is there any way to get animated hair into Octane, either via the standard hair or via ICE strands (I think there's a free ICE hair system somewhere)?
face
Chris_TC wrote:Is there any way to get animated hair into Octane, either via the standard hair or via ICE strands (I think there's a free ICE hair system somewhere)?
I´m work current on strands ;)
But i have some problems.
Should i use instand shapes or a standard cylinder?
And the biggest problem is to know the position on the strand.
Strands are nurbs curves, the position between two points are also cubic interpolated...
At the moment, i can create a nurbs curve from a strand. I hope to find a way to get a location on the curve that gives me the position.
The easyest way would be to get a postion on a U-value. That means, i can specify a U-value and the result is a position.
face
Chris_TC
Do you know the Save render mesh plugin? It allows you to save the render geometry of anything to an OBJ file.
Maybe including something similar would be easier than "rebuilding" the strands? But I really don't know anything about this stuff, so I'm sure you'll figure it out :)
face
Yes, i know it. It runs as a shader.
That would not so simple to implement ;)
I will use the nurbs-curve technique.
I rescale every point from a instance shape in a y-range from 0 to 1. With this i know where every point lie on the curve.
face
cgndev
Face~
I hope support of Attributes_Color.
Sorry, My English is bad..
i7 860 | Ram 4GB | Geforce GTX260 Core 216 | Win7 64x Kor | Octane with Softimage 2011 for x64 , ICE
face
cgndev wrote:Face~
See here ;)
face
http://www.refractivesoftware.com/forum ... 231#p25231
cgndev
Yes. I have seen..
:( That's sound is sad......
cgndev
Then... Face.
Is possible or do you have plan a support as Attributes_Integer?
I would get variety to Instanced particles by textures like this(http://cgndev.com/xe/files/attach/image ... G-0066.jpg).
Return to “Autodesk Softimage XSI”
