OctaneRender® for 3ds max® v2.23.2 - 2.1 [OBSOLETE]
oguzbir
it seems like v2.1 has brought many changes in the maxscript connectivity.
My octane shortcuts script has problems with the new version
Most important buttons now do not work.
I'll update the script when I'll have the time to update it.
best,
My Portfolio
RobSteady
A roadmap like the guys over at Corona have would be a great thing!
https://corona-renderer.com/blog/spring ... ct-update/
Octane for 3ds Max v2.21.1 | i7-5930K | 32GB | 1 x GTX Titan Z + 2 x GTX 980 Ti
RobSteady
HELP!
I just installed this version and went back to 2.21.1 and when I open an Octane scene Max hangs/crashes (AppHangB1) as soon as I open the Material editor.
Tried other releases as well...
oguzbir
RobSteady wrote:HELP
I just installed this version and went back to 2.21.1 and now the material convertor is broken; it crashes Max as soon as I open the material editor (AppHangB1).
Could that be because of your default max scene that is maxstart.max which has version 2.1 materials already set at mat editor.
Or your default material library that loads at startup
My Portfolio
RobSteady
This is what I did:
Installed this version, went back to 2.21.1, opened a scene I saved with this release (2.21.1) opened the Material Editor -> Max crashes/hangs up.
RobSteady
I had an edited MaxStart file but I just reverted back to scanline.
Open Max, switch to Octane, open Material Editor, get Octane Material -> Crash/Hangs
oguzbir
RobSteady wrote:I had an edited MaxStart file but I just reverted back to scanline.
uninstall octane before downgrading then?
you can try merging the scene into an empty scene.
My Portfolio
RobSteady
I'm sorry, I had the license activated on another pc and my brain deactivated :oops:
So the last posts can be easily deleted :roll:
JimStar
Next version HERE.
Locked
Return to “Releases”
