External GPU on laptop
Daniel79
Hello guys,
I bought a lenovo thinkpad yoga 12 , since the use we have to do is fine by me .
I wondered , however , whether it will be possible to have an external GPU with which maybe able to use octane .
If so, how should I do ?
SORRY, MY ENGLISH IS BAD!
2 Xeon quad core E5440_8gb Ram_Nvidia GeForce 2GTX 780ti 3Gb/Nvidia Quadro K2000_Win10 64bit_Octane 3.02_Rhinoceros3D
glimpse
think there's no easy & simple option =) but there is one:
if You would remove wireless module (& get USB stick for that functionality)
You could use something like this, but with different interface
However this way would force You to modify Your metal case..
..& there is always slight chance that it would not work in the end.
so if I were You, I'd probably wait till V3 is going to work on CPUs..
..otherwise simply different beast for mobile work would fit better.
Daniel79
But get a riser like this, and connect via USB 3 and a a external PSU don't work?
glimpse
..this is very simmilar option, but as You see USB cable is used only to conect mPCIe with PCIe.
as far as I know, GPUs don't work so well via USB (if You conect to where You typically place flash/mouse, etc..)
- but this field always evelve & there migh be a solution..try do a bit of research =)
enigmasi
even thunderbolt is not that fast for gpu
glimpse
enigmasi wrote:even thunderbolt is not that fast for gpu
actually more than enough..before You fell any difference =) but thunderbold has it's own problems combined with GPUs..
Daniel79
the Vidock support wrote me this:
I dont suggest to use Vidock on lenovo whitout ExpressCard slot yet.
So i don't know what to do to take advantage of my laptop ... I find it strange that not be possible to do anything !!! boh
ExpressCard to usb3 o thunderbolt to usb3 is not a solution?
glimpse
if You wanted as simple as possible plug and play solution different laptop would fit better (as there are gaming oriented rigs that have inbuild proprietary conectors from companies like Alienware, MSI, etc.)
if You don't like bulky looks & want something small You can alwasy choose something with 9x0M (or even older) mobile GPU that supports CUDA - the way to go now, but later versions of Octane will bring support for CPUs & other GPUs aswell.
in Your case, as offerend one of the best deal woud be to get a mentioned kit with mPCIe conector, relocate Your wifi module (from mPCIe to USB - simplyu get cheap dongle) & conect Your GPU into mPCIe.
Would it work 50/50 (do Your homework before or simply get the kit & try out for Yourself). So there are solutions - You just need to spend Your time (or more money before making a decision to get laptop).
P.S. if You're looking for something to cary, get small liek SFX(L) brick with fully modular cables =) even make some DIY housing - it will take less space. Drop a line if You need more info & we'll try to help You out =)
Daniel79
can you explain by image this option?
I like to undestand better...
Another question :
Is possible get a gpu 9x0m on my lenovo that have integrated card Intel HD 5500? replace it?
Daniel79
I posted your image but i don't undestand very well how work it...
How do I connect to the laptop?
