crazy replicas
marcus1070
Hi, i'm getting some issues using replicator and a particle modifier to change it. Every time that there are something driving the falloff, it get a strange behaviour. like an animation or other driver in the position channel. you could see it in the screenshots. in Modo render its all fine, its a octane issue.
- Win 10 Pro 64bit
- 64gb Ram
- RTX 3090
- RTX 2080
- Nvidia driver version: 516.94
- Cinema 4d r25
- Plugin version Studio+ 2022.1(r7)
http://www.marcusrizzo.com
Hi - can you send me the scene causing problems pls?
marcus1070
Hi Paul, i recreated the problem in a new scene, and when the falloff is just driven, it works well. But if its animated or the driver is animated... the result comes weird. here is the link to the scene:
https://dl.dropboxusercontent.com/u/443 ... rouble.lxo
- Win 10 Pro 64bit
- 64gb Ram
- RTX 3090
- RTX 2080
- Cinema 4d r25
Thanks for supplying this file Marcus. This problem is fixed in the next release. If you have an urgent need for the fix, pls email or PM me and I will send you a pre-release.
Return to “Foundry Modo”
