material converter - all faces turned black
Jorgensen
hi
i just used the material converter tool and all my facaes turned black in the 3ds viewport :-/
is there anything i can do to get 'normal' colors again?
thanks
jorgensen
gueoct
check the orientation of the polygons.
Intel i7-970 @3,20 GHz / 24 GB RAM / 3 x EVGA GTX 580 - 3GB
kevindark
Make sure your viewport is "Shaded". If the material is textured also make sure that in your Material Editor the map for diffuse materials is turned on with "Show shaded materials in viewport". You will need to do this for every material with textures in order for them to be visible in the viewport. (Easier for UVW Map)
You can also go to Views>Show materials in viewport as>Shaded materials with map. ( I don't know is this is needed)
If the problem persists, open your "Octane Viewport" (Right click > Open Octane Viewport) in perspective view mode to see if the textures is right, save the file and re-open it.
Check the images for example. Works for me most of the time.
Cheers.
coilbook
same here mix materials do this all the time
jblessing
Same problem here. Any fix?
None of those things above made a difference. The "Show shaded materials in viewport" is greyed out.
Win 8.1 | 4.1ghz 5960x | Cinema 4D R20 / 3ds Max 2018 | 2 x Titan Z + 980
Win 10 | 3.0ghz 2697 v3 | Cinema 4D R20 / 3ds Max 2018 | 4 x 980ti hydros
4 x Win 7 | 4.0ghz 5930k | 4 x Titan Black or 4 x 980ti
Return to “Autodesk 3Ds Max”
