Your Displacement Settings
Moderator: BK
erik-nl
And here's AlFan's displacement map for V6 on M6 HD (Subdiv level 3).
Settings: 0.3 for Height and -0.15 for Offset.
DAZ Studio's maptransfer wasn't completely flawless in the seam areas, but a bit of Photoshop TLC will easily repair that.
It is a shame though that DAZ Studio cannot export them at 16 bit colour depth, so some depth information will get lost as a result of this conversion.
Even so it's nice to have them.
Cheers!
Erik
aoktar, the c4dOctane plugin developer, has found a very useful trick on how to use bump or normal maps together with displacement:
http://render.otoy.com/forum/viewtopic.php?f=87&t=48024
The trick is to connect twice a material with bump or normal to the two materials slots in a mix material and use the separated pin of the mix material for connecting the displacement. and obviously works also with DAZ ;)
happy rendering
ciao beppe
larsmidnatt
bepeg4d wrote:Hi,
happy rendering
ciao beppe
that is clever.
Win10 x64
i9 10900k 64GB
2080S 8GB
DS 4.15 OcDS Prime ^_^
linvanchene
@ erik-nl
Thank you so much for sharing your results.
Let's hope that more DAZ3D character artists will in the future create both bump / normal and also a displacement map versions for characters.
While I had some luck using bump maps in the displacement slot custom created displacement maps are certainly the prefered choice.
@ bepeg4d
Thank you a lot for posting that amazing find here as well.
Win 10 Pro 64bit | Rendering: 2 x ASUS GeForce RTX 2080 Ti TURBO | Asus RTX NVLink Bridge 4-Slot | Intel Core i7 5820K | ASUS X99-E WS| 64 GB RAM
FAQ: OctaneRender for DAZ Studio - FAQ link collection
erik-nl
Woheey!
Just tried that displacement+bump workaround, and it worked splendidly!
Thank you soooo much Beppe for posting about it here!
Cheers1
Erik
hi all,
I'm glad to help here, I'm absolutely inexpert with DAZ, but I have some experience with Octane and the integration is so good and intuitive that is pleasure to use it inside DAZ :D
Happy rendering
ciao beppe
erik-nl
That trick worked well with the somewhat complicated auto-generated (but of course modified) mixed material for Michael 6 HD's skin.
I did reduce the displacement settings somewhat from 0.3 and -0.15 to 0.2 and -0.1 and added some HD-detail from the Boris, Aging, and Veins sets (at SubDiv 3).
Oh, and the beard is by Laticis Imagery:
http://laticis.deviantart.com/art/Latic ... -521807046
Here's the result:
erik-nl
Thanks Beppe, sure!
I've only removed the diffuse maps from the skin material and the beard fibre geometry, the rest was left unchanged.
Return to “DAZ Studio”
