OctaneRender® for 3ds max® v2.23.2 - 1.9 [OBSOLETE]
oguzbir
JimStar wrote:Guys, just wait.
I'm working on a huge plugin refactoring to make the MaxScript language fully supported and add other important features that require this refactoring.
So I just have no time to sit on the forums currently...
Hi JimStar,
I have no attention to interrupt your work.
But when you feel you're kind of close to integration.
Please make sure all or most of the Render Setup values can be accessed via maxscript.
to test that.
All you should do is
Open maxscript listener. In the white area you should write the below line (octane must be set as the current renderer.)
show renderers.current
Below you can find the current results tested with Octane and Scanline Renderer.
Best,
My Portfolio
acc24ex
I have a dream..
Imagine this - a connector or a bridge between 3ds max live plugin and adobe Lightroom - in case you didn't try lightroom - you can use it as a live post processing tool like exposure but also tonemapping, color presets, highlits, shadows, much better vignetting, bw presets, lens correction, HDL adjuster, hue saturation, whites, black, contrast - all the stuff found in photoshop
- you learn how to use it in like 10 minutes, and realise there is no easier tool for live photo processing with a lot of power - like picassa only pro level
- imagine like a sort of live feed bridge, press on the octane viewport button to launch the current render in 32 bit mode into lightroom and another to refresh current - this could upgrade usability of octane to more than 50%
gabrielefx
the new advanced Vray frame buffer does a lot of these things.
I think it's possible to have many picture controls directly in the Octane GUI.
RobSteady
Guys, let's focus on one thing after another; if the whole max script thing is working this is a big step forward...
Octane for 3ds Max v2.21.1 | i7-5930K | 32GB | 1 x GTX Titan Z + 2 x GTX 980 Ti
Phil_RA
Repeating this one just to make sure this regression doesn't fall in the cracks: if the renderer is paused, you can't see any of the post effect value changes unless you resume the rendering. I should be able to change things like bloom values, Response, etc., while the renderer is paused, as it was before.
Goldisart
It is convenient to work with the tool Snaps toggle -- but if exposed glass and the subject have to edit and do an air layer in millimeters. You can avoid extra work ? Thanks
Goldisart
I can't find the control button of all cameras via General settings previously, this button was in previous versions
mikinik
Goldisart wrote:It is convenient to work with the tool Snaps toggle -- but if exposed glass and the subject have to edit and do an air layer in millimeters. You can avoid extra work ? Thanks
I have no such problems, even if polygons are coplanar. problem in your scene. try make smaller value ray epsilon.
r9 3900x/64Gb/2070s/2070/win10x64/3dsmax2021
oguzbir
Also try to extend the precision parameter in max settings. that way you can lower the epsilon setting. like 0.0000001
My Portfolio
Goldisart
+1 help :)
box.zip
(31.48 KiB) Downloaded 300 times
Return to “Releases”
