Hi ,
I've a problem using displacement and SSS at the same time : when I switch on the Displacement ( in the mix material containing a diffuse one and a 'spécular' one ) , then the SSS on my diffuse material seems bugging : you can see on the images above , that when Displ is on , the SSS is badly calculated and gives strange results . Is there something to do to fix this , maybe I made something wrong ?
( I'm in PT kernel , i use the displacement in the mix mat and not the diffuse mat )
( I put an uvs screenshot too in the case it could help )
thanks by advance
Displacement and SSS
... Same problem here.
Win7 x64 - Intel Core i7 920 (2.67 GHz) - Geforce GTX 285 - 12Go RAM
www.wipix.fr
www.wipix.fr
Clement, that would be nice to share your solution, don't you think? Thank you!
Win 8.1 64 | Geforce GTX780 x 4 | i7 5960X | 64GB
yep MrPinoux
, in fact I asked in the general forum too hoping other developers could find any interest , and I replied with the 'solution' :
http://render.otoy.com/forum/viewtopic. ... 84#p238933
it was the UVs of the back which were still in symetry projection ( so Right and left side overlapping ) and as soon as I unwrapped fully the uvs ( no overlapping areas ) it has worked .
I hope this is a bug and will be fixed because I often need to keep right and left UVs side overlapping sometimes to just paint one texture side .. if we have to unwrap all the uvs to make it work , this will be very annoying .
Win7 x64 / Cinema4D R15.064 / I7 4930K - Nvidia gtx770
Perfect, that's nice and it makes sense.
